Skunk2 Camshafts problem!!! help
Old Jan 20, 2007 | 08:35 AM
Zer0skll's Avatar
Default Skunk2 Camshafts problem!!! help
I put in new skunk2 Stage 2 camshafts in my H22,
I had to but a new distributor because the teeth where u connect the cams broke,
so at the end of the installation I put in the brand Disrtibutor and the car won't start.
checked the plugs
cheked the connections
help please
Old Jan 20, 2007 | 08:38 AM
AllMTRWH0R3's Avatar
Default Re: Skunk2 Camshafts problem!!! help (Zer0skll)
Does it not start cause the battery is dead or does not start because you have one of the sensor on backwards. Check the AIT sensor those are usually flipped around.
Old Jan 20, 2007 | 08:40 AM
98vtec's Avatar
moderator emeritus
Default Re: Skunk2 Camshafts problem!!! help (AllMTRWH0R3)
make sure all the grounds are bolted down and are clean.
Old Jan 20, 2007 | 08:43 AM
Zer0skll's Avatar
Default Re: Skunk2 Camshafts problem!!! help (98vtec)
hmmm ill check that right now.
the sensor is fine.
Do you have to check anything after you install the distributor or do something afterwards?
Old Jan 20, 2007 | 08:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0skll &raquo;</TD></TR><TR><TD CLASS="quote">hmmm ill check that right now.
the sensor is fine.
Do you have to check anything after you install the distributor or do something afterwards?</TD></TR></TABLE>
Aslong as you put it on the right position then it should be fine. Usually what happends is people take stuff off when they don't need to. So just go over everything. Take your time, please. Triple check yourself, it's a good starting point just to check that. Sounds like you did a good job, it's something very small you overlooked. It's how we learn
Old Jan 20, 2007 | 10:10 AM
dinko's Avatar
most common mistake
^^^ like someone said. triple check everything...
salandrew09
Jul 10, 2009 04:57 PM
DIS-1
12
Jun 20, 2007 01:40 PM
cincispeedemon
Aug 2, 2004 09:58 AM
BRAWDY03
May 13, 2004 04:50 PM
1991dxhatch
Apr 24, 2004 07:41 AM
