d16z6 help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok im putting a d16z6 in my ef hatch now can i use my mpfi manifold on the d16z6. and also can the d16a6 dizzy fit on the d16z6 i just want to make the motor obdo so i dont have to change wiring.
thank you
thank you
Not that quick, trust me, especially at Orlando Speedworld
Besides, it takes more than a motor to make you go down the track; you need to factor in suspension, gearing, traction, weight, weather, and driver ability among things.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Not that quick, trust me, especially at Orlando Speedworld
Besides, it takes more than a motor to make you go down the track; you need to factor in suspension, gearing, traction, weight, weather, and driver ability among things.</TD></TR></TABLE>
Guest
Posts: n/a
umm.. slow down there chief, read up a couple post before you ask the same question 10 times just to expletive it up 9 times.
"You can't use an OBD-1 distributor unless you convert to OBD-1 (which you should do anyways) "
yes you can i used my obd0 wire harness and dizzy on my obd1 swap/// i got pics of what 2 do with the dizzy...if u intrested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex »</TD></TR><TR><TD CLASS="quote">yes you can i used my obd0 wire harness and dizzy on my obd1 swap/// i got pics of what 2 do with the dizzy...if u intrested</TD></TR></TABLE> Well duh! If you convert over to OBD-1 you can do whatever you want with the wires on the distributor and harness side. But he isn't converting to OBD-1, so he is S.O.L.
I have this same swap in a ef sedan and it runs right around a 15.oo in the 1/4 with i/h/e center force clutch, and rewired to obd1 running a p06 converted to a p28 with an eprom chip and a 7500 redline. but yea i had the same problem with my dizzy and had to buy a d16z6 dizzy for it to run right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex »</TD></TR><TR><TD CLASS="quote">dr_latino999 i have a jdm d15b in my car and my wire harness is still obd0 with no conversions ..91 ex dizzy..</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">the only distributors that bolt to the Z6 head are all OBD-1 distributors.</TD></TR></TABLE> Do you have all three bolts attached to the Z6 head without either modifying the distributor legs or making a really nifty bracket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 »</TD></TR><TR><TD CLASS="quote">what should i do in the 1/4 mile with a d16z6 in a ef hatch</TD></TR></TABLE>
With a half-assed pre-OBD setup like you're planning to do, it probably won't be any faster than the D16A6. In fact, it will likely be slower.
If you convert to OBD-1 properly and use a P28 ECU like you should, the car will run 15s easily. Low 15s are possible with bolt-ons.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex »</TD></TR><TR><TD CLASS="quote"> nifty bracket</TD></TR></TABLE>
KURUPTinc
Sep 4, 2005 08:41 PM
