What's involved to swap from cable to hydro tranny and KEEP hydro??
Old Jan 20, 2007 | 07:06 AM
RyanA's Avatar
Default What's involved to swap from cable to hydro tranny and KEEP hydro??
I'm sure someone will know this. I want to know if I can just go full hydro on my CRX instead of doing a cable/hydro kit that keeps the cable drive. I want to put a hydro master and slave cylinder in there to keep the nice, smooth operation and get rid of the nasty clutch cable. Can this be done or is there not enough room to put a master cylinder in the car?? Did a search and only came up with people getting the Hasport cable/hydro kit that still uses the cable....
Old Jan 20, 2007 | 07:10 AM
dr_latino999's Avatar
Default Re: What's involved to swap from cable to hydro tranny and KEEP hydro?? (RyanA)
If you want to use OEM parts, you will have to cut a nice hole in the firewall to get the Clutch master cylinder to fit. If you are dead set on it, look Wilwood and Tilton product pages as they offer clutch pedals with relocated master cylinders.
Old Jan 27, 2007 | 02:45 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
I've thought the same myself, with all the mechanical crap in the cable systems, I'd really like to figure it out. Does the cable clutch work on the same fulcrum that a hydro does? like does the hydro pedal pull the CMC or push it? Does anyone know?
As for the actual travel of the piston in the CMC, I think that could be corrected with the use of spacers or washers.
Old Jan 29, 2007 | 07:08 PM
ComeOnKip's Avatar
i'm suprised no ones tried this, or has said "heres the link to the write up n00bster" yet.
Old Jan 29, 2007 | 10:22 PM
Mista Bone's Avatar
D Tranny Guru
contact "BigTuna" on http://www.d-series.org
but it's not worth it IMHO.......
Old Jan 29, 2007 | 11:38 PM
koshir's Avatar
Default Re: (Mista Bone)
I have that on my civic,
B16A2 engine with hydro set up OEM, we used a 92' pedals and cut the firewall for cilinder, couldn't get willwood pedals so soon...I works fine and is now almost 2years in car...check out my topic about CRX I think that I have photo there...but no DIY
CYA
Old Jan 30, 2007 | 07:19 AM
ComeOnKip's Avatar
well i've heard some issues with that whole bracketry that a couple of the motor mount companies make...any opinions?
Jdmek920
Jan 22, 2013 09:53 PM
young-gun92eg
Feb 2, 2012 11:56 AM
wrestler72
Sep 17, 2007 07:24 AM
SnowSurfer
10
Jun 15, 2005 01:57 PM
Faust
Aug 9, 2002 06:45 AM
