ride height for stock crx
Old Jan 20, 2007 | 05:29 AM
austincrx's Avatar
Default ride height for stock crx
I have a 1989 CRX Si with tokico illuminu struts, and stock springs. Will the struts lower the car any, even if the springs are stock? I'm wondering because I want to buy some stiffer springs, but I'm not sure which ones, I'm thinking ground control with adjustable sleeves, or H&R race springs because tirerack has them on special now for the 1989 crx si.
thanks
Old Jan 20, 2007 | 05:44 AM
ChickenH's Avatar
Default Re: ride height for stock crx (austincrx)
its the springs that adjust height.adjustable springs have been noisy in my experience. if you want adjustable get coilovers.
I threw away a set of skunk2 coilovers because the ride was rock hard and rattled over every bump. I like the eibach ones
http://eibach.com/cgi-bin/star....html
Old Jan 20, 2007 | 09:46 AM
e jay one's Avatar
Default Re: ride height for stock crx (ChickenH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH &raquo;</TD></TR><TR><TD CLASS="quote">I threw away a set of skunk2 coilovers </TD></TR></TABLE>
tell me your not serious. i personaly like skunks yea there stiff but i like it. next time you want to throw away parts mail them to me.
Old Jan 20, 2007 | 11:33 AM
crxnj's Avatar
new stock replacement shocks with stock springs may actually raise the car a bit..
Old Jan 20, 2007 | 02:12 PM
philkehn's Avatar
any good suggestions for a good replacement shock for a stock shock, or any where with good deals
Old Jan 20, 2007 | 03:58 PM
crxnj's Avatar
Default Re: (philkehn)
kyb gr-2's are nice for stock replacement,also tokico blues.
ebay ususally has good deals when you buy 4.
Old Jan 20, 2007 | 04:17 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austincrx &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1989 CRX Si with tokico illuminu struts, and stock springs. Will the struts lower the car any, even if the springs are stock?</TD></TR></TABLE>
No, because Illuminas have the perch set at the exact same position as on the stock damper bodies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">new stock replacement shocks with stock springs may actually raise the car a bit..</TD></TR></TABLE>
Only if the OE springs were sagging or broken. Dampers do not affect ride height at all unless the spring perch position has been altered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">any good suggestions for a good replacement shock for a stock shock</TD></TR></TABLE>
Good inexpensive stock-replacement dampers include Tokico HP ("Blue") and KYB GR-2. Anything significantly better is going to cost at least 50% more than those, but would be overkill for stock springs.
Modified by Targa250R at 12:13 AM 1/21/2007
Old Jan 20, 2007 | 08:10 PM
crxnj's Avatar
Default Re: ride height for stock crx (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah,my front springs were sagging. So the new shock raised the front up a bit in my case.
Old Jan 20, 2007 | 08:12 PM
Targa250R's Avatar
be professional
Default Re: ride height for stock crx (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Yeah,my front springs were sagging. So the new shock raised the front up a bit in my case.</TD></TR></TABLE>
Yeah, that's typical.
Both of my original front springs were broken due to rust, so my car sat slightly lower than stock as well. I replaced them with new coilovers, and it sits even lower now.
JacksonD
22
Feb 18, 2010 11:07 AM
smallttocs
Oct 22, 2008 06:11 AM
kevo2k6
Suspension & Brakes
10
Jan 20, 2005 08:01 PM
Nader_D
Apr 17, 2003 06:47 AM
SC0TT
10
Apr 2, 2002 06:25 AM
