My tuck
Old Jan 20, 2007 | 01:39 AM
pegboy's Avatar
Default My tuck
Before Standard EF9 with B16A
After tucked B18c Hybrid
A lot of wiring
Old Jan 20, 2007 | 01:53 AM
90sedan's Avatar
Way more clean afterwards
Specs of the motor?
Old Jan 20, 2007 | 02:02 AM
misha's Avatar
Default Re: (89-civic-DX)
loooks good
Old Jan 20, 2007 | 04:56 AM
HBK's Avatar
HBK
Default Re: (misha)
I know its pricey, but a new aluminum radiator would liven that engine bay up and make the bseries stand out even more.
Old Jan 20, 2007 | 06:02 AM
HatchMo's Avatar
looks goood!!!
Old Jan 20, 2007 | 06:11 AM
vw eater's Avatar
how long did it take you?did u solder every connection?
Old Jan 20, 2007 | 07:48 AM
Pee Wee's Avatar
Default Re: (vw eater)
looks good considering you left the wiper motor and fluid tank in there
Old Jan 20, 2007 | 08:02 AM
HondaCivicSiR1's Avatar
Default Re: (Pee Wee)
where did you put your battery?anyone notice where the m/c and b/b is?
Old Jan 20, 2007 | 08:04 AM
oodie's Avatar
Default Re: (HondaCivicSiR1)
Looks good how long did it take you?
Old Jan 20, 2007 | 08:27 AM
Mrcrx28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">where did you put your battery?anyone notice where the m/c and b/b is?</TD></TR></TABLE>
I assume the battery is in the trunk. Well, the car is LHD, so the brake system is on the left side above the intake.
Old Jan 20, 2007 | 08:28 AM
e jay one's Avatar
Default Re: (oodie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrcrx28 &raquo;</TD></TR><TR><TD CLASS="quote">
I assume the battery is in the trunk. Well, the car is LHD, so the brake system is on the left side above the intake.</TD></TR></TABLE>
you mean rhd
Old Jan 20, 2007 | 05:32 PM
pegboy's Avatar
RHD. Took a week from pulling old motor. Building new motor. Remove dash etc, Cleaning crap. Reroute all wiring. Rewiring all engine harness. Dumping new motor, reassemble car.Yes all soldered. Battery is behind drivers seat. Car is fully stripped. Sunroof patch etc...
Specs
b18c1 block
b16a1 head
pr3 pistons
b18c cams
BRE tuned obd0 jdm pw0
quaife lsd
lightweight flywheel
Still my daily so wanted washer bottle. Rad is still good so no replacement yet.
Old Jan 20, 2007 | 09:16 PM
mr_hahn73's Avatar
Default Re: (pegboy)
Looks really good!
Old Jan 20, 2007 | 11:20 PM
d16t-hatch's Avatar
looks awsome, what did you do for the fuse box did you extend the wires and put it inside the car also did you have to extend the side wire warness for the headlights and all that or were they long enough to go through the fender wells?
Old Jan 20, 2007 | 11:25 PM
Takumi665's Avatar
Default Re: My tuck (pegboy)
Nice man. I would never be able to do this, I'm way to impatient
Old Jan 20, 2007 | 11:34 PM
89EF_Turbo's Avatar
Default Re: My tuck (Takumi665)
I have to ask...where do you end up putting all the wiring and harness's at afterwords? I'm pretty new to tuck's and stuff, most I ever did with them was on my old bagged 84 s-dime, but that had almost nothing for wiring. I love how much cleaner it looks...I think I should do one on mine over the winter.
Old Jan 20, 2007 | 11:44 PM
djphonics's Avatar
Default Re: My tuck (89EF_Turbo)
Clean *** engine bay man. I could eat off of that.
Old Jan 21, 2007 | 12:26 AM
N2HIFI's Avatar
that will give you a rough idea on where the majority of the wiring goed plus a idea on where to relocate the fuse box to and how to mount it.
these pics are not finished pics of my tuck ... more of a almost finished just need to tidy up some misc stuff.
my swapped and tucked 89 std
chris
Old Jan 21, 2007 | 12:37 AM
CarAudioPro's Avatar
LOL WOW i was like damn, how did you tuck the brake booster.........? then i realized its a RHD. i need to go to sleep.
Old Jan 21, 2007 | 01:12 AM
pegboy's Avatar
It would have been harder if I had a/c or a heater to work around let alone interior. Here is where I put the fusebox. Most wires needed to be extended about 200mm.
Old Jan 21, 2007 | 03:06 AM
STDClayton's Avatar
sick
Old Jan 21, 2007 | 03:43 AM
lonestarEE9's Avatar
From: Magdeburg, represent Deutschland..y0, Germany
Default Re: (STDClayton)
i &lt;3 r63.....
nice ride..
My Bitch
Old Jan 21, 2007 | 04:11 AM
B16CRXT's Avatar
Fire!
Old Jan 21, 2007 | 07:17 AM
N2HIFI's Avatar
Default Re: (B16CRXT)
good point about the hvac box, my car is a daily also but it gets driven year round, a/c was never a concern since it was not a factory option on this car but i need the heater.
I removed the washer reseivor though and put a WHOLE lot of rainx on the whindsheild.
i will probley do somthing more extream with my new 95 hatch i just got but i have also of ideas just have to figure out what way i want to go with it
chris
Ricey_Bricey
Dec 29, 2009 07:27 AM
EFSedan#6
Oct 27, 2007 05:40 PM
Lucky-13
Apr 22, 2007 09:08 PM
S2KP
Sep 26, 2004 04:19 AM
Plan B
Dec 13, 2002 04:51 PM
