PCV or EGR on 98 V6 Accord.
Old Jan 19, 2007 | 07:51 PM
Legendaryyaj's Avatar
Default PCV or EGR on 98 V6 Accord.
Ok so my 1998 Accord V6 is acting up lately because of this cold weather. I dont know whether its the PCV valve or the EGR.
Problem is that when I start it up it idles rough by revving up and down. I have to turn it off and restart it to make it go away. Im not sure whether its the PCV valve or the EGR. When I bought the car the owner said the EGR valve was already replaced since there was a recall on it so I dont know if it can still go bad or went bad again.
Help is much appreciated.
Old Jan 20, 2007 | 09:10 AM
jbhondaman's Avatar
Default Re: PCV or EGR on 98 V6 Accord. (Legendaryyaj)
The problem is with your idle air control valve. It is placed on the bottom of your throttle body housing. One of 2 things either low coolant level so check radiator level or IAC valve is bad, replace it.
Jack jaxz
Engine Management and Tuning
Mar 30, 2016 04:17 AM
pdelo
Nov 16, 2014 09:57 AM
brendizzle
Sep 1, 2012 03:06 PM
