idel problem
i have a ls-turbo, and having the same problem, just that it only idel at 3,000 when its cold and trying to heat up..but onces its heat up, it goes from 1,000-2,500 back and fourth and repeats for a while....
I'd check for vacuum leaks, make sure the idle is adjusted correctly, and use a can of carb cleaner to spray around the intake gasket area to see if the idle drops. If it does, thats a good indicator that you've got a blown gasket.
wedgenix
May 27, 2005 07:54 PM
