which throttle body gasket w/ 64mm TB??
Old Jan 19, 2007 | 04:20 PM
eg6sir88's Avatar
Default which throttle body gasket w/ 64mm TB??
jsut like the title states.. which throttle body gasket should i get if i'm gonna run a 64mm throttle body.. i know most Honda throttle bodies interchange, so that means a bigger gasket from another Honda will work, but which one?? TIA
i'm also wondering what size the studs are that hold the distributor on???
Old Jan 19, 2007 | 04:54 PM
hondachris1994's Avatar
I could b wrong but I think the B-series gaskets are all the same
Old Jan 19, 2007 | 05:05 PM
hannah's Avatar
Default Re: which throttle body gasket w/ 64mm TB?? (eg6sir88)
i agree..im pretty sure all the gaskets are the same for the b series.
Modified by hannah at 6:20 PM 1/19/2007
Old Jan 19, 2007 | 07:20 PM
eg6sir88's Avatar
well.. i was thinking about an ITR gasket.. because the TB is 62mm and other b-series are only 58-60mm
Old Jan 19, 2007 | 08:56 PM
xhatchracerx's Avatar
Default Re: (eg6sir88)
i would use itr 62mm then cut the rest
Old Jan 21, 2007 | 03:52 PM
eg6sir88's Avatar
well, i ended up using the b16 gasket since i already had one and cut off the excess w/ a razor..
trailblazer
Jul 9, 2018 08:22 PM
67mmlsv
Jan 19, 2015 12:21 PM
bigweedy
Dec 29, 2009 01:13 PM
honda06si
Honda Civic (2006 - 2015)
Aug 3, 2006 02:10 PM
ShawnR
Dec 4, 2005 09:26 PM
