b16a into ef9 ecu question. need help
Old Jan 19, 2007 | 03:19 PM
sirsatan's Avatar
Default b16a into ef9 ecu question. need help
dropping a b16a obd0 into my ef hatch and cant find an addapter for the ecu. the one that came out of the car is a PM9 the one that i recieved with the engine is a PR3 and are both obd0. but the only adapter harnesses i can find are to go from obd0 to obd1. anybody know where i can locate the adapter harness that i need?
Old Jan 19, 2007 | 04:18 PM
89EF_Turbo's Avatar
Default Re: b16a into ef9 ecu question. need help (sirsatan)
I honestly have never seen one. I've seen obd0 dpfi to obd1 mpfi, but that's about it. I think you're going to have to break out your soldering iron and start doing a mpfi wiring swap, and then add the necessary wiring for the pr3.
Old Jan 19, 2007 | 04:27 PM
fourthgenhatchB17's Avatar
No need for a jumper if you're using an obd-0 PR3. You will need to convert to MPFI though if its not already done in order for the car to run.
Old Jan 19, 2007 | 04:37 PM
89EF_Turbo's Avatar
Default Re: b16a into ef9 ecu question. need help (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">No need for a jumper if you're using an obd-0 PR3. You will need to convert to MPFI though if its not already done in order for the car to run.</TD></TR></TABLE>Just doing the mpfi swap will let the car run, but not very well. You'll throw codes for vtec solenoid, oil pressure switch, knock sensor, and secondary o2 sensor. Those are the extra wires I was talking about.
Old Jan 19, 2007 | 04:42 PM
Default Re: b16a into ef9 ecu question. need help (89EF_Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89EF_Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Just doing the mpfi swap will let the car run, but not very well. You'll throw codes for vtec solenoid, oil pressure switch, knock sensor, and secondary o2 sensor. Those are the extra wires I was talking about.</TD></TR></TABLE>
I wasnt repsonding to you but ok. Its hard to tell what the original poster is asking. As i understood it, he thinks he needs a conversion harness so his obd-0 pr3 will plug in? The ecu plugs are the same across the board for obd-0 so it will plug in. As for what additional wiring is needed, he wasnt specific enough and really didnt even ask about it.
Old Jan 19, 2007 | 05:25 PM
89EF_Turbo's Avatar
I wasnt repsonding to you but ok. Its hard to tell what the original poster is asking. As i understood it, he thinks he needs a conversion harness so his obd-0 pr3 will plug in? The ecu plugs are the same across the board for obd-0 so it will plug in. As for what additional wiring is needed, he wasnt specific enough and really didnt even ask about it.</TD></TR></TABLE>My apologies...wasn't sure exactly who it was directed at. You're right though, the info given was kind of vague.
Old Jan 19, 2007 | 06:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89EF_Turbo &raquo;</TD></TR><TR><TD CLASS="quote">My apologies...wasn't sure exactly who it was directed at. You're right though, the info given was kind of vague.</TD></TR></TABLE>
No worries man, maybe when he gets more speicific we can help him out. OR he could just use the search function, lol.
Old Jan 19, 2007 | 06:09 PM
menappi's Avatar
Your ef9 came with a pm9?? If you're saying it dpfi...just convert it and use the pw3..?
Old Jan 19, 2007 | 09:09 PM
sirsatan's Avatar
Default Re: (menappi)
the pm9 has the one white and two black plugs and the pr3 came with the 3 gray plugs. i dunno if that helps but i really dont know what other specifics to give.
Old Jan 19, 2007 | 11:07 PM
Default Re: (sirsatan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirsatan &raquo;</TD></TR><TR><TD CLASS="quote">the pm9 has the one white and two black plugs and the pr3 came with the 3 gray plugs. i dunno if that helps but i really dont know what other specifics to give. </TD></TR></TABLE>
Well heres an easy test. Have u tried plugging it in to your car?
Old Jan 20, 2007 | 05:40 AM
Zaakro's Avatar
is there a OBD1 PR3?
Old Jan 20, 2007 | 08:11 AM
sirsatan's Avatar
oh, wait. try plugging it in??? maybe i should do that..... yes ive already tried that. im not a complete moron. thats how i came to discover that it doesnt fit. like i said the connectors are different colors and sizes. someone said that all of the obd0 ecu have the same connectors. so i thought i would check and see if that made a difference or not. should i just order a obd0 to obd1 and try it or buy a pw0 ecu. which would be my best bet?
Old Jan 20, 2007 | 08:17 AM
oodie's Avatar
Sounds like you have a obd1 pr3 just might a well convert to obd1 if you not in a hurry to get on the road down the line there are more options of tuning a obd1 car if your going to do work to it.
Old Jan 20, 2007 | 08:45 AM
sirsatan's Avatar
Default Re: (oodie)
ok. guess ill try that. but the list of honda ecus doesnt list an odb1 pr3. just obd0. thats why i didnt know what i should get. but hell. if its not what i need then ill just sell it and buy a different ecu or something.
Old Jan 20, 2007 | 04:35 PM
The only reason i said try plugging it in was b/c u stated u had an obd-0 swap that has the matching obd-0 ecu, which theoretically should plug right in.
I do believe there was an obd-1 PR3. I have an OBD-0 B16 ECU to save u some headaches. Let me know if you're interested.
Old Jan 22, 2007 | 02:36 PM
sirsatan's Avatar
well im gonna try to use the obd0 to obd1 conversion harness but i really dont care to do the full conversion bc im gonna sell the car. but how much do you want for that ecu?
Old Jan 22, 2007 | 05:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirsatan &raquo;</TD></TR><TR><TD CLASS="quote">well im gonna try to use the obd0 to obd1 conversion harness but i really dont care to do the full conversion bc im gonna sell the car. but how much do you want for that ecu? </TD></TR></TABLE>
There is more to it than just the conversion harness. At the very least, you will also need an obd-1 distributor and a 4 wire O2 sensor.
$100 for my obd-0 B16 ecu.
KDvtec5757
Sep 24, 2008 06:24 PM
nonvtecpos06
Nov 28, 2004 08:52 AM
casper625
Nov 24, 2003 08:04 PM
Hybridize
Oct 6, 2003 02:01 PM
