ef b18a swap
im new to honda and everything...went from dodge neons to now honda's kinda happy with it..but i want to know everything i need to do to swap a b18a into my 91 ef. i think its a obd0 ef.i have the motor and b16 y1 tranny..just wanna know the wiring harness stuff and ecu etc...and everything else i need and need to know about the swap cuz im ready to get everything and put it in....thanks...like i said im new to honda's and searched but didnt find everything.
https://honda-tech.com/zerothread?id=131949
https://honda-tech.com/zerothread?id=1193782
and look in the faq thread
If you're an Si then you don't have to worry about wiring.
If you're DX you have to convert to multi port fuel injection.
You need custom made shift linkage (cut and weld) or buy one from places like Hasport.
You need to make a dent in the engine bay where the alternator goes because it won't fit.
You need 90-91 Integra axles and make sure you take the dust covers off the ends.
You need 90-91 Integra intermediate shaft.
You need mounts.....www.innovativemounts.com
Use the Integra rad hoses.
You need an Si map sensor or use the Integra one (I think...).
Grind off the front mount that sits ontop of the cross member if you want easier installation....or just bash it in.
If you have more questions please PM me.
i dont know if the car is an si but it does have leather seats dont know if it came wit the car or someone swaped em in..how do i check if its a si or dx..and the motor i bought i dont think i have everything for it..i have the intake mani the headers and the tranny and the clutch **** i just want a list of the rest of the **** i need for the motor...and i want to rebiuld to motor(replace everything wit oem stuff like new gaskets and piston rings)cuz i dont know how many miles is one the motor...thanks for u guys help...
Definitely not an Si. Sounds like a Civic STD (Standard base hatchback) . . . is the transmission a 4-speed?
You'll have to do a DPFI -> MPFI wiring harness conversion to complete this swap. If the car is indeed a STD, you will also need DX/LX/Si or EX front suspension knuckles (or at least just the hubs) for the axles to work.
trampuscool
Dec 20, 2010 08:16 AM
