91-93 interga cluster, need help quick
Old Jan 19, 2007 | 10:45 AM
misha's Avatar
Default 91-93 interga cluster, need help quick
1. is it cable?
2. does it fit a 91 4 door dx?
3. did anyone seen the write up?
thanks alot
Old Jan 20, 2007 | 02:01 AM
misha's Avatar
Default Re: 91-93 interga cluster, need help quick (misha)
anyone???? , speedo=cable? please help i can get one for 20 bux, but i gotta hurry
Old Jan 20, 2007 | 02:04 AM
misha's Avatar
bump
Old Jan 20, 2007 | 09:16 AM
misha's Avatar
wil this work???
https://honda-tech.com/zero...age=1cuz mine isnt xsi
please help, or the cluster will be gone while we speak
Old Jan 20, 2007 | 10:18 AM
mra4886's Avatar
search cluster and read through the results you will find info on difrent clusters into a ef
Old Jan 20, 2007 | 10:20 AM
mra4886's Avatar
Default Re: 91-93 interga cluster, need help quick (mra4886)
this guy has a realy good write up on a gsr cluster install.
http://www.ef-honda.com/ben/DCcluster.php
Old Jan 20, 2007 | 12:50 PM
misha's Avatar
thanks, mine is pre 94 cluster and it out of rs, so would the wires be same a xsi?
Old Jan 20, 2007 | 03:02 PM
misha's Avatar
anyone, can i just reliy on that write up and hope the wires r the same or there difference??????
Old Jan 20, 2007 | 03:10 PM
VtecSyndrome's Avatar
I don't know those clusters exactly, meaning I never had them both in my hands comparing the two. The wire colors are very likely similair in color but they will not match up pin for pin, I will promise you that much. I would go with the GSR cluster since it would be easier to source wire diagramsd and it has a higher speedo, not to mention its in MPH not KPH. Go with the GSR!! p.s. it is cable in case you were not sure yet. (I had a '92 GSR)
Old Jan 20, 2007 | 04:01 PM
misha's Avatar
Default Re: 91-93 interga cluster, need help quick (VtecSyndrome)
yes, but i got the rs already, it was 6 bux, im not even kidding you. Well if i get the diagram for it can i put it? Meaning, can it be done?
Old Jan 20, 2007 | 04:04 PM
I've seen the DA Integra cluster installed in the EF chassis if that is what you are asking, the fit is too tight in my opinion but I have seen it done. as far as the wires go, just look up the wire diagrams from a haynes manual and work it out.
Old Jan 21, 2007 | 08:04 PM
misha's Avatar
ok, i cant find the diagram for, hynes doesnt seens to have it.
anyone can hook me up with a link for a usdm da cluster diagram. please!
Old Jan 22, 2007 | 12:37 PM
misha's Avatar
i cant find it, please help
Old Jan 22, 2007 | 01:20 PM
gsrpedro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misha &raquo;</TD></TR><TR><TD CLASS="quote">i cant find it, please help</TD></TR></TABLE>
HERE ARE THE PINOUTS!!! I HOPE THIS IS WUT U LOOKIN FOR!!!GOOD LUCK
90-93 integra ls pinout
PIN...Wire Color...Wire Function
A1...Yellow/Red...Seat Belt Reminder Light
A2...Green/Red...Parking Brake Switch Light
A3...Green/Black...Hatch Open Indicator Light
A4...Green/Red...Low Fuel Indicator Light
A5...Yellow/White...Fuel Gauge
A6...Yellow/Red...ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7...Red Gauge...Lights, Dash Light Dim
A8...Empty
A9...Red/Black...Gauge Lights
A10...Green/Yellow...Right Turn Signal Indicator
B1...Green/Blue...Left Turn Signal Indicator
B2...Red/Blue...High Beam Indicator
B3...Blue/Red...ABS Indicator Light
B4...Blue...Tachometer
B5...Green/Red...Door Open Indicator Light
B6...Yellow/Green...Engine Coolant Temp Gauge
B7...Black...Ground
B8...Yellow...Ignition Power
B9...Green/Orange...Malfunction Indicator (Ck Eng.) Light
B10...Black/Yellow...Charging Sysem
B11...White/Blue...Charging System (Battery) Light
B12...Yellow/Red...Low Engine Oil Pressure Light
C1...Red...Cruise Control Unit
C2...Red/Black Gauge Lights...Cruise Control Dimming Circuit
C3... Empty
Old Jan 22, 2007 | 06:09 PM
HondaCivicSiR1's Avatar
Default Re: 91-93 interga cluster, need help quick (gsrpedro)
whats wrong with the second pic i'm tring to do the same cluster swap and i would like as much info on it to do it also
Old Jan 22, 2007 | 08:51 PM
misha's Avatar
Default Re: 91-93 interga cluster, need help quick (HondaCivicSiR1)
THANK YOU SO MUCH!!!!!!
ps. mine is out of rs, will it be the same as ls, i guess yes, right?
Old Jan 22, 2007 | 09:19 PM
misha's Avatar
ok, yes thouse r correct, and here are the correct pictures(of my cluster), all same colours
Old Jan 22, 2007 | 09:28 PM
4DRmafia's Avatar
noticed ur gauge is in kmh!
Old Jan 22, 2007 | 09:32 PM
misha's Avatar
ok, one more question
would the 91 dx 4dr pin outs be the same as 91 crx pin outs?????
90-91 CRX gauge cluster pinouts -------------------------------
C.
1. Left Turn ---- (Green/Blue)
2. High Beam ---- (Red/Blue)
3. Coolant Temp -- (yellow/Green)
4. Dash Brightness ----- (Red)
5. Gauge Lights ----- (Red/Black)
6.
7. E-Brake ---- (Green/Red)
8. Oil Pressure --- (yellow/red)
9. Check Engine Light ---- (Green/Orange)
10. 12v Power ---- (Black/Yellow)
11. Battery/Alternator Light ---- (White/Blue)
12. Tachometer --- (Blue)
D.
1. Ground ---- (Black)
2.
3.
4. Trunk ---- (Green/Black)
5. Seat Belt ---- (Blue/Red or Blue/yellow)
6. Fuel Gauge --- (Yellow/White)
7. 12v Power ---- (Yellow)
8. Right Turn --- (Green/Yellow)
Old Jan 22, 2007 | 09:33 PM
misha's Avatar
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">noticed ur gauge is in kmh!</TD></TR></TABLE>
yea, i live in Canada
Old Jan 23, 2007 | 03:09 AM
Default Re: (misha)
are those the da integra clips?or ef's clips?
Old Jan 23, 2007 | 03:28 AM
gibsanez's Avatar
Default Re: (HondaCivicSiR1)
You will need to use to the integra clips. I had to open the pockets of the cluster up a little bit to fit it better, and quite a bit of grinding of the dash and the cluster edges. All the ls/rs/gs/gsr will be the same, as i swapped my ls out for a gsr.
https://honda-tech.com/zerothread?id=1755357
Old Jan 23, 2007 | 04:23 AM
misha's Avatar
Default Re: (gibsanez)
thouse are the integra clips, and EF shouldnt fit anyways, yes i am prepared for some little fabrication.
Old Jan 23, 2007 | 06:32 AM
gibsanez's Avatar
Default Re: (misha)
if you have a dremmel tool you're set
Old Jan 23, 2007 | 06:24 PM
misha's Avatar
sorry, but whats a dremmel tool ?
