Look what I did...:(
Old Jan 19, 2007 | 08:22 AM
harmonator84's Avatar
Default Look what I did...:(
Well I finally got to installing my new oring on my injectors. I took them out and made them shine with alittle brake cleaner. But as I was installing the new orings I dropped one. When I went to pick it up I seen it was split right down the side. I could have cried...So now I only have 3 injectors....
These injectors came out of a 95 honda civic. I do have some injectors from my crx hf and dx. I know these are different injectors because I looked....So what I am wondering is should I put the 3 injectors on from the civic and put 1 on from the HF or should I just put all 4 on from my HF.
Heres some pics of the damage.
Here are the injectors when I first took them out!
Heres what I used to clean the injectors
Here they are after I cleaned the tips...the look pretty good now!
Now here is what I done while putting the orings on...
Old Jan 19, 2007 | 08:32 AM
Got_soy's Avatar
Default Re: Look what I did...:( (harmonator84)
just pull it off, the pintle cap dont do anything but protect them from people who drop them. I dont have and Pintle caps on my 450.
Old Jan 19, 2007 | 08:33 AM
ludesrv's Avatar
The plugs from the 95 and the Hf are different. OBD0 and OBD1 plugs I beleive. Check that first.
Go to a scrap yard and pick up a new to you one. Just remove it and pocket it, they won't notice an injector.
Old Jan 19, 2007 | 08:36 AM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">The plugs from the 95 and the Hf are different. OBD0 and OBD1 plugs I beleive. Check that first.
Go to a scrap yard and pick up a new to you one. Just remove it and pocket it, they won't notice an injector.</TD></TR></TABLE>
Yea I know they are different. I checked.
I am thinking about trying a junk yard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">just pull it off, the pintle cap dont do anything but protect them from people who drop them. I dont have and Pintle caps on my 450.</TD></TR></TABLE>
Well can I take the pintle caps off of another injector and put it on that one?
Old Jan 19, 2007 | 08:37 AM
Default Re: (harmonator84)
And how do you get that cap off????
Old Jan 19, 2007 | 08:43 AM
Got_soy's Avatar
pull, that it. dont even work about going to a junk yard
Old Jan 19, 2007 | 10:50 AM
project.one's Avatar
New User
Default Re: (Got_soy)
i have a few of those laying around that i can send you one, just pay for the shipping fee.
Old Jan 19, 2007 | 11:20 AM
143MYVTECEF's Avatar
Default Re: (project.one)
Dude just take a dremel and CAREFULLY cut the rest of the cap of it you cant pull it off.. Like they said before its just there to protect the spray nozzle from being damaged.
Old Jan 19, 2007 | 12:56 PM
Default Re: (143MYVTECEF)
Well I pulled and pulled and it WILL NOT come out.
So i just said forget it and pulled as much off of it as I could and put it in anyways...
It is working so far...
Old Jan 19, 2007 | 02:57 PM
STREETWERKZ's Avatar
you dont need that plastic piece. it doesnt effect direction of the spray or anything.
all 4 injectors will work fine.
thewrai6th
May 7, 2011 09:13 AM
driftam1
Apr 21, 2008 10:19 AM
sporkcrx
Oct 21, 2006 01:07 PM
LODOSS
Nov 10, 2001 03:25 PM
