Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium?
Old May 15, 2002 | 07:28 PM
Spocko's Avatar
Default Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium?
Well I know for one that NGK's are the best to use in Honda engines, so with that I am deciding between NGK's 7 series copper plugs, or the 7 series NGK iridium plugs.(One heat range colder than stock). I know that people say avoid platinum plugs like the plague, but what about iridium? Or is copper and turbo the only safe mix? Any help thoughts on this would be great, as I am getting my motor back soon and need to put new plugs in there...
Old May 16, 2002 | 02:49 PM
Spocko's Avatar
Default Re: Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium? (Spocko)
Anyone- what everyone uses the same plugs then? Someone here must know something
Old May 16, 2002 | 02:52 PM
Jared's Avatar
Never used copper, but I'm told that the iridium plugs are not resistant at all to detonation and tend to come unglued. Myself, I prefer the Bosch F6DPs.
Old May 16, 2002 | 02:53 PM
Jared's Avatar
Default Re: Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium? (Jared)
Go here for more info:
https://honda-tech.com/zerothread?id=178964
Old May 16, 2002 | 02:56 PM
Ben Huynh's Avatar
Always go copper. All other materials such as iridium or platinum may last forever, but they do much for performance. You can also get 4 sets of NGK copper plugs for one set of iridium or platinum plugs.
Old May 16, 2002 | 02:57 PM
falcongsr's Avatar
What is this crap?
Default Re: Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium? (ben@importparts.com)
copper has lower electrical resistance.
Old May 16, 2002 | 06:24 PM
Spocko's Avatar
Default Re: Okay- spark plugs for a NEWLY BUILT Turbo H22A- copper or iridium? (falconGSR)
Yeah- I read that, and the main info poster there seemed to rank the Bosch 6 range double platinum's higher than the NGK 7 range plugs(very similar heat ranges between the B6 and NGK7). But from what a lot of people say- avoid plats. So I think for now I will stick with the NGK 7 series copper plugs, and tune with them, and then just replace them every 10K. Just can't remember which EXACT NGK plugs to get(part number)...
Old May 16, 2002 | 06:49 PM
Jared's Avatar
Should be the BKR7E or BKR7E-11 for an upgraded ignition.
7mile
May 12, 2017 09:05 AM
Bruce Banner
Sep 25, 2009 02:46 PM
B18B1DOHC
Nov 17, 2003 02:08 PM
dustywebber
Nov 11, 2003 11:59 PM
migo
Nov 9, 2001 07:39 PM
