Street tires, to heat up or not to heat up prior a run
Old Jan 19, 2007 | 04:14 AM
Pippen_001's Avatar
Default Street tires, to heat up or not to heat up prior a run
Some one wrote in a tread that cold street tires are as good as warmed up street tires. What are your thoughts on this? Does it make such a great difference?
Old Jan 19, 2007 | 06:55 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Street tires, to heat up or not to heat up prior a run (Pippen_001)
You might want to ask your question on the Drag Racing forum...
Old Jan 20, 2007 | 05:50 PM
vtecsi00's Avatar
Default Re: Street tires, to heat up or not to heat up prior a run (nsxtasy)
the only time you need to heat them up for is if you are drag racing!!!! tires will warm up after you drive on them for some time about a mile or two depending on the temp outside
turbolshatch
May 21, 2006 09:35 AM
Stryker908
Jul 25, 2002 01:59 AM
