Spacer help needed!!!
Old Jan 18, 2007 | 09:25 PM
JayDeeMDc2's Avatar
Default Spacer help needed!!!
Hey there if i got a set of HX and i want to put those on n integra what size spacer do i need and would i be able to use the stock studs???
Old Jan 18, 2007 | 10:26 PM
vtecsi00's Avatar
Default Re: Spacer help needed!!! (JayDeeMDc2)
hx wheels of a civic?? if it is going on an integra other than a type r they bolt right on
Old Jan 19, 2007 | 10:58 PM
JayDeeMDc2's Avatar
Default Re: Spacer help needed!!! (vtecsi00)
dont i need spacer to fit the civic hx rims on my intergra?
Old Jan 20, 2007 | 08:50 PM
JayDeeMDc2's Avatar
Default Re:
Would i need to change to longer wheel studs?
Old Jan 21, 2007 | 07:11 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Re: (JayDeeMDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeMDc2 &raquo;</TD></TR><TR><TD CLASS="quote">Would i need to change to longer wheel studs?</TD></TR></TABLE>
It depends on how thick the spacers are, and how many turns you lose on the lugs. If you can't get at least six full turns on the lug nuts (seven is even better), then yes, you need to get longer studs.
0LdsKooL
May 8, 2008 12:21 AM
ptnguyen
Jul 24, 2007 06:51 AM
99_red_si
Aug 4, 2006 06:49 PM
awdriscol4
Suspension & Brakes
11
Jul 3, 2005 12:21 PM
Civic Hx-T
12
Aug 27, 2003 07:33 PM
