So I swapped a b16 into my hatch...Is this engine placement right?!!?
Old Jan 18, 2007 | 08:53 PM
elf's Avatar
elf
Default So I swapped a b16 into my hatch...Is this engine placement right?!!?
Okay, so it may just be me and the fact that the car is currently alot higher then it would normally be, but everyday I keep thinking more and more that this engine/tranny placement isn't right. Here's the setup I have on the car:
91 Dx hatch.
B16a out a da6.
DC 4-1 header.
Fluidyne Radiator, made for da.
Flex-a-lite fan, costom fit for ef, made for eg.
Innovative mounts. The steel ones. I bought these a few years ago, so I'm not sure if they are possibly, like, first gen ones? Ones with little R&D, so engine/tranny placement may not be ideal.
I'm not sure if you can tell from the pictures below, but I just cant get over the fact of how close the motor sits up front!!
The axle placement seems okay...not straight, but not at that much of an angle.
Pass side:
Driverside:
Is is just me?! Am I just **** about this!? Or is the combination of the radiator/fan/header that pushes everything forward?
Any input is appreciated.
Old Jan 18, 2007 | 08:57 PM
.Manny.'s Avatar
Touching My Member
that look about right. our engine bays have limited space. the big *** radiator (just like mine) doesnt help either. but you are ok. dont worry
Old Jan 18, 2007 | 08:58 PM
Jerms's Avatar
looks fine (normal) b series sit forward alot but thats fine
axle placement is fine too not to much of a angle
Old Jan 19, 2007 | 09:05 AM
elf's Avatar
elf
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (elf)
cool. thanks guys
Old Jan 19, 2007 | 10:24 AM
.Grimace's Avatar
footwork mastery
ooooh get it running jesse. looking good always liked your hatchback.
Old Jan 19, 2007 | 12:35 PM
Furyof4's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (Gremice)
That definitely sits farther forward than my hasport swap. It doesn't look like very good placement to me.
my .02
Old Jan 19, 2007 | 12:39 PM
CroSi's Avatar
Good placement. Look at the distance between the firewall and intake manifold.
Old Jan 19, 2007 | 12:49 PM
civicjdmb16a's Avatar
Default Re: (CroSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroSi &raquo;</TD></TR><TR><TD CLASS="quote">Good placement. Look at the distance between the firewall and intake manifold.</TD></TR></TABLE>
Old Jan 19, 2007 | 12:51 PM
goforbroke's Avatar
MEAT PATTY
Every company has different mounts which are going to position your motor differently from the next. You also have a huge *** radiator so that might make it appear like its sitting so far forward when it really isn't.
I have hasport mounts and yours just like mine, but it might be different if they were side to side. Who cares, as long as your motor is sturdy in place and not going anywhere then it really doesn't matter.
Don't worry about ground clearance they all suck, but you can't do jack about that.
Old Jan 19, 2007 | 07:06 PM
HONDA RR's Avatar
looks right to me
Old Jan 19, 2007 | 08:20 PM
elf's Avatar
elf
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote"> Who cares, as long as your motor is sturdy in place and not going anywhere then it really doesn't matter.
Don't worry about ground clearance they all suck, but you can't do jack about that. </TD></TR></TABLE>
Yeah, it's not that big of a deal to me, I was just curious. And ground clearence....**** was scraping with the d-series, so bring it! lol.
Old Jan 19, 2007 | 09:36 PM
Ls_dx's Avatar
jesse. looking good. that b16 looks sexy in there. i got that **** in my trunk call me tomorow !!1!
Old Jan 19, 2007 | 09:45 PM
oodie's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (Ls_dx)
Yea that looks right no clearance in 88-91
Old Jan 19, 2007 | 10:12 PM
GsrTurboCRX88's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (oodie)
looks good but i would put the timing belt cover on if i were you
Old Jan 19, 2007 | 10:32 PM
Cheeech's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (GsrTurboCRX88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">looks good but i would put the timing belt cover on if i were you</TD></TR></TABLE>
It is on, isnt it?
Old Jan 19, 2007 | 11:08 PM
be8teensee1's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (Cheeech)
it looks on to me
Old Jan 19, 2007 | 11:10 PM
RCautoworks's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (be8teensee1)
Your trans is on backward
Old Jan 19, 2007 | 11:15 PM
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (90blackcrx)
Made you look , looks good
Old Jan 20, 2007 | 10:12 AM
elf's Avatar
elf
um yeah, all peices are on snug!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Made you look , looks good</TD></TR></TABLE>
lol, I was all, " !!!"
Old Jan 20, 2007 | 10:51 AM
nitekidsef9's Avatar
Ive got billit hasport mounts and the reason i got them was because they situated the engine in the EXACT same spot as it sits in a JDM ef9 bay. Some mounts move the motor a bit forward which tends to put the axles on a bad angle and ive known people to snap axles cause of the bad angle.
Just my 2cents
Old Jan 20, 2007 | 11:48 AM
gsxr1k05's Avatar
Default Re: So I swapped a b16 into my hatch...Is this engine placement right?!!? (nitekidsef9)
i dont know about the axle placement to give any info on that, but i will say that big *** radiator makes it look far front.. i bet a 1/2 civic one would fix that
Old Jan 20, 2007 | 01:30 PM
viciousef9's Avatar
Default Re: (90_EF_Si)
you look ok but you should get new motor mounts and a shift linkage form the same company to assure that the placement is right. i think you might be a little to close to the radiator
Old Jan 20, 2007 | 01:39 PM
91ed9's Avatar
Default Re: (viciousef9)
^^ the fluidyne rad is bigger than stock thats why it looks liek it sits closer... the engine looks about right ... i got a half rad from an eg and kinda ghetto slanted it but now my fan doesnt hit the header!!
looks good
Old Jan 20, 2007 | 02:01 PM
HxCforever's Avatar
looks like it's in the right spot to me. i thought the same thing when i did my b-swap on my old hatch
Old Jan 20, 2007 | 02:20 PM
Crx Jimmy's Avatar
Default Re: (HxCforever)
looks fine. it cant go much farther back the manifold is close to the firewall. thats how it should sit
