head bolt are killing me
You should have no prob with a nice 2' breaker bar. At least mine came out fine, i used a 1/2" drive 2' craftsman breaker bar. Work your way from the outside in, and loosen each bolt a 1/4 turn at a time or you could warp the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt »</TD></TR><TR><TD CLASS="quote">there is no way those are a lefthanded thread</TD></TR></TABLE>
They are threaded like a normal bolt would be. Righty tighty lefty loosy. Who told you they were left threaded?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt »</TD></TR><TR><TD CLASS="quote">kick it popeye style
Why not hit it, Fonzie style?
Aaaayy!
Aaaayy!
NEVER remove head bolts with an impact.
If you guys can't get head bolts out, do you really think you're ready to work on an engine?
Just use a breaker bar, and follow the procedure in the Helms to prevent any damage to the head or the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">NEVER remove head bolts with an impact.
You know I've heard that before, and believe it. But I've impacted off all my heads on my personal motors and haven't had any ill effects yet.
Not recommending it, just sayin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt »</TD></TR><TR><TD CLASS="quote">i'm swaping the head out and the bolts going into the block are so tight that iam bending the breakerbar trying to get them out. any hints?</TD></TR></TABLE>
so what ever happened to the head bolts? did you get them off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">just wait til your impact gun skips slightly and you round a head bolt...</TD></TR></TABLE>
Never had my gun "skip".......and my impact sockets have a very tight fit......
yeah i got this special socket for rounded off heads, it digs into the bolt and the harder you pull the tighter it grabs onto the bolt head...... needless to say those basterd where a breeze to get off with that on my side.
i still dont get it though, Me + 3ft breaker = easy 250 ft-lbs. head bolts are only torqued to 73 ft-lbs. something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt »</TD></TR><TR><TD CLASS="quote">yeah i got this special socket for rounded off heads, it digs into the bolt and the harder you pull the tighter it grabs onto the bolt head...... needless to say those basterd where a breeze to get off with that on my side. </TD></TR></TABLE>
how did the bolts get rounded off? were you trying to use a standard socket first or something?
i have seen the head bolts round several times, usually on F series heads though. never had it happen myself, but I was in the shop when it did. then the special socket for rounded head bolts failed pretty badly when the teeth were ground off. then out came the drill....and that was fun helping the other mechanic drill the head of the bolt off...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">i have seen the head bolts round several times, usually on F series heads though. never had it happen myself, but I was in the shop when it did. then the special socket for rounded head bolts failed pretty badly when the teeth were ground off. then out came the drill....and that was fun helping the other mechanic drill the head of the bolt off...</TD></TR></TABLE>
i'm glad that socket worked, because i was starting to get the freak out point and planning for the worst.
you know of anywhere i could get the new bolts, i checked autozone and places like that and they said it was a dealer only item and i know the dealer with rip me off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">ARP</TD></TR></TABLE>
i saw their site, so you would highly recommend them
