Unbalanced Tire or What?!?!
Ok I just got new tires and rims...well of course I put them on and I get a crazy
vibrating bumpy feeling. I made sure everything was tight, lug nuts are fine and there are no wheel thats unbalanced right?? How bad is it to drive with unbalanced wheels?? I have to go like 5 miles to work....can I make it?
Did you do it yourself? I work at discount tire and yes balancing is a big deal. Did you set everything to the right torque specs?
yeah I did it myself and everything seems to be at the right torque and snug.
It just vibrates like crazy...kinda feels like im hitting tiny bumps.
do you think i can drive to work like that...i dont have to go over 50
cool...ill go to work like that and get them fixed on the way home or first thing sat.
I didnt know that unbalanced tires can vibrate that much....it really feels like im hitting little bumps in a perfect rythm.
Also look into Hub Centric Rings . That might be your problem. Get your wheels balanced first, then if the problem is still there .. then order a set of these for your wheels and your problem is gone. Search and you'll get results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 »</TD></TR><TR><TD CLASS="quote">Also look into Hub Centric Rings . That might be your problem. Get your wheels balanced first, then if the problem is still there .. then order a set of these for your wheels and your problem is gone. Search and you'll get results.</TD></TR></TABLE>
definitely need hub rings. also, even with the rings its possible to put the wheel on slightly off. just make the sure that when you put the wheels on that the wheel lugs are centered in there holes.
First thing you should do is take your wheels to a local tire shop and have them double check the balancing on the wheels, then if you still have vibrations check the bearings, then get some hub centric rings, then if you still have vibrations it could be bad axles...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">First thing you should do is take your wheels to a local tire shop and have them double check the balancing on the wheels, then if you still have vibrations check the bearings, then get some hub centric rings, then if you still have vibrations it could be bad axles...</TD></TR></TABLE>
x2 good instructions
Tire are not a perfect circle when they are made, therefore getting the balanced is a must.
Well guys...It was a balance...and one of the damn tires wasnt mounted right on the rim! The guy said i was lucky the tire didnt fly of! damn anyway I got tire put on rim the correct way, balanced, and alignment. So car is drivin like a dream now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smo0th »</TD></TR><TR><TD CLASS="quote">
Tire are not a perfect circle when they are made, therefore getting the balanced is a must.</TD></TR></TABLE>
lol, not exactly
the tire should be pretty close to a circle or you would never get a smooth ride......for example having a flat spot on a tire from locking up the brakes
balancing corrects the mismatch of the tire and rim.....the weight of both is what's not evenly dispersed when they are made......lol sometimes you can get a tire and rim that coordinate and balance eachother out without any weights......or if the match is way off you can turn the tire 180deg on the rim and lower the amount of weight needed to get it to zero.
however, if you have a bent wheel or out of round tire then the ride will never be smooth
lol, not exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fadedline »</TD></TR><TR><TD CLASS="quote">Ok I just got new tires and rims...</TD></TR></TABLE>
Glad to hear that a balance/remount fixed your problem.
When you say new tires/rims, do you mean brand-spanking new from a company or brand-new but from a private seller?
If it was from a company, I'd like to know who it was if you don't mind mentioning their name.
Yeah the were brand spanking new. And I dont mind telling anyone about the crappy company because ive had so many problems with them..first off i only got three rims from them and the customer service blamed it on fedex and of course fedex blames it on them. then they wont ship the 4th tire until they get claim back from fedex!! so i say f that and told them to charge my card for one more wheel and ship it asap so i can put them on...and they were supposed to put the money back in my account after they get claim back.....well of course no money yet. THen to top it off they cant even mount the tire right or balance them!!! Now ive also had to spend an extra $75 getting everything balanced and mounted right! So im calling them back and making them put money back in the account or im contacting better business!
So moral of the story stay away from wheelsnext.
Im sure some of have seen the site and if not just google it and stay far far away!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fadedline »</TD></TR><TR><TD CLASS="quote">So moral of the story stay away from wheelsnext.
Ah, I had a sneaking suspicion it was wheelsnext or one of those companies.
Thanks for the warning!
