Best clutch for a LS Turbo?
Old May 15, 2002 | 06:47 PM
Audi A4's Avatar
Default Best clutch for a LS Turbo?
ok i have a 98 ls turbo ill be running about 6 daly but will go up at the track. whats the best setup?
Old May 15, 2002 | 06:52 PM
SIK IN DA HED's Avatar
New User
Default Re: Best clutch for a LS Turbo? (DRAG lll INTEGRA)
ACT heavy duty 6puck. thats what i use.
Audi A4's Avatar
Default Re: Best clutch for a LS Turbo? (dlplayboy)
what do u run daily 6-7 pds[/B]
Old May 15, 2002 | 07:40 PM
NWPNOMORE's Avatar
Banned
ACT clutch worked for me
Old May 15, 2002 | 07:53 PM
shamoo's Avatar
Will you make something up for me please?
That should be the best. ACT is good....Heavy Duty pressure plate isn't too tough on you like the Extreme series. It's good for the street, plus good grabbing power for the track.
The 6 puck from ACT is an unsprung disc though, so be careful. It will probably chatter. ACT claims that the 6 puck chatters LESS than the 4 puck. I have the 4 puck and it chatters a lot. However, a few days ago, there was a thread where people have said that the 6 puck is a lot worse than the 4 in terms of streetability.
Old May 15, 2002 | 07:55 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Best clutch for a LS Turbo? (shamoo)
So far no complaints with an Exedy flywheel/clutch combo...
Old May 16, 2002 | 07:16 AM
b18b98's Avatar
nuff said
Old May 16, 2002 | 07:19 AM
OneFastLS's Avatar
Default Re: Best clutch for a LS Turbo? (b18b98)
EXEDY or ACT. Two of the best in the business.
Old May 16, 2002 | 09:57 AM
X2BOARD's Avatar
Default Re: Best clutch for a LS Turbo? (OneFastLS)
I am running a clutchmasters stage 5 Pressure plate mated to my stock clutch done over in Kevlar and had the flywheel notched... really short pedal travel, ALMOST stock feel on engagement AND great grab ! Plus it SHOULD last almost as long as a stock clutch on a stock LS. I run an LS tranny and 12psi DD
Old May 16, 2002 | 03:25 PM
lsturbo's Avatar
I've used ACT 4 puck and Clutchnet 4puck on my LSTurbo
both of them hold up fine...
Old May 16, 2002 | 03:41 PM
GSRrR's Avatar
Default Re: Best clutch for a LS Turbo? (lsturbo)
Clutchnet stage 2 works for me. Daily 6.5 but no track.
Old May 16, 2002 | 04:19 PM
Cone's Avatar
Default Re: Best clutch for a LS Turbo? (GSRrR)
Clutch Masters Stage 3 Carbon/Kevlar...lasts long, very grabby...I don't think ACT is quite as good. And he won't need any 4 or 6 puck clutches (especially with un-sprung hubs ) on a daily driven car only running 6 psi.
-Andrew
Old May 16, 2002 | 06:00 PM
Audi A4's Avatar
Default Re: Best clutch for a LS Turbo? (Stealth 95 GS-R)
thx guys
Old May 16, 2002 | 06:10 PM
SleepinGSR's Avatar
What is the opinion of the centerforce dual friction clutch? It says it is like a stage II clutch. I read an article about it and it has the counter weights on the PP to make the pedel easier to push.
Old May 16, 2002 | 06:53 PM
Cone's Avatar
Default Re: Best clutch for a LS Turbo? (SleepinGSR)
I have heard a lot of bad things about Centerforce, both on web boards, and from racers I have talked to one-on-one...
Old May 16, 2002 | 06:58 PM
Audi A4's Avatar
what about oem?
Old May 16, 2002 | 07:00 PM
SleepinGSR's Avatar
I dont disbelieve you, but what stuff?
Old May 16, 2002 | 07:04 PM
Audi A4's Avatar
there is always gonna be a bads tory on every part. thats just how it is
Teamdiesel
36
Mar 27, 2010 03:14 PM
specvkid18
11
Jun 2, 2007 03:29 PM
silver_nteg
Oct 26, 2003 09:24 AM
riceburnah
Apr 21, 2003 08:28 AM
dc2pffsssttt
Feb 5, 2003 07:51 PM
