Interchangeablilty between h22 and f22b1
Old Jan 18, 2007 | 03:34 PM
rollercosta123's Avatar
Default Interchangeablilty between h22 and f22b1
i was wondering what parts are interchangeable with each other such as alternator ac. im not sure but intake manifold? exhaust? let me know please. thanks
Old Jan 18, 2007 | 05:09 PM
hatchness135's Avatar
Default Re: Interchangeablilty between h22 and f22b1 (rollercosta123)
bump...
in for info.
Old Jan 19, 2007 | 09:19 AM
gianinline's Avatar
No, the intake manifolds are different, exhaust manifold is also different. The block of the motor itself, share pretty much the same parts, but from the head up.... ...things change.
F22B1 is SOHC and H22 is a DOHC.
If you do a good search, I think you will find whether alternator, and ac's can be swapped.
Old Jan 20, 2007 | 09:08 AM
H22 CL's Avatar
I think the F22B Intake manifold will bolt onto an H22, ive seen swaps into 5th gens that keep the F22 intake manifold for the cruise
Old Jan 21, 2007 | 03:23 PM
ricepicker's Avatar
Default Re: (H22 CL)
The F22 AC is compatible on the H22 with the F22 AC bracket, and the same goes for the Alternator. Not sure about the intake manifold. and the header is a definite no because the exhaust ports differ.
F22 Header:
O OO O
H22 Header:
O O O O
jarol220
Dec 22, 2010 07:52 AM
TemecCivic
May 13, 2009 03:02 PM
the_eyecon
Jul 31, 2003 06:51 PM
