i want more torque on my sh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">u guys could just answer his questions........
People forget that we are here to help, and I am sick and tired of the flaming, stupidity and disinformation.
If you can't help, then shut up.
If somebody asks a noobie question, then help point him in the right direction by showing him where to look.
Telling people to search without showing them how is a disservice.
Sure, people need to lurk more, but I'm willing to bet that each of you has been as guilty as the dumbest noobie.
</TD></TR></TABLE>People forget that we are here to help, and I am sick and tired of the flaming, stupidity and disinformation.
The quickest cheapest trick I have found to add a little torque is to get an extra iab plate out of an accord with an f22a6 is about the easiest place to find one, its the plate between the upper and lower plenum if you didn't know. You can grab one of those and remove the butterflies from it and slap it under your iab plate existing in your car now, you will have to get longer bolts/studs but its a cheap way to increase your plenum volume which in turn supposedly increases torque. I have done this on my car and you can feel a difference, there are many write ups on the internet with pictures if you are unsure of anything I have said here, good luck man
