cali bar (yes i know this is thread #5145214)
Old Jan 18, 2007 | 01:32 PM
alacard's Avatar
Default cali bar (yes i know this is thread #5145214)
alright, so the car is a 99 hatchback. the plan is to swap a 99+ gsr engine or a 99+ b16 (from a civic si) then get the motor bared (sp) in california. my understand was that as long as the engine was the same year or newer than you car and you swapped over all the emissions stuff, you will pass. but i was recently told that the engine had to be offered in the car. (i.e. a coupe can put a b16 in it because it came in the si, but a hatch cant because it never came in the hatch)...i had never heard this up until now. can anyone confirm this for me?
(please dont tell me to search...because i did and couldnt find anything that dealt with this specifically)
thanks.
Old Jan 18, 2007 | 01:36 PM
Luserkid's Avatar
Default Re: cali bar (alacard)
Whoever told you that was pulling your leg. The only motor that matters weither its a coupe, hatch or truck is the B20 (CRV) motor because its a light truck. Other then that it doesnt matter what the motor came out of. Most important is the year.
Old Jan 18, 2007 | 01:40 PM
B16b-EJ8's Avatar
Default Re: cali bar (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> Most important is the year. </TD></TR></TABLE>
and emissions equipment
Old Jan 18, 2007 | 01:41 PM
alacard's Avatar
exactly what i thought. but this guy seemed certain. not only that but he had a buddy to back him up..so it made me wonder.
thanks for the confirmation,
Old Jan 18, 2007 | 01:42 PM
beaneg6's Avatar
k20's never came in hatches or any other car besides the rsx, i am now seeing them being bar'd in eg chassis, someone is lying to you,
Old Jan 18, 2007 | 01:43 PM
alacard's Avatar
Default Re: cali bar (beaneg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">k20's never came in hatches or any other car besides the rsx, i am now seeing them being bar'd in eg chassis, someone is lying to you,</TD></TR></TABLE>
yeah, i thought it was BS. but like I said, he had a buddy to back him up and he spoke from what he said was experience.
Old Jan 18, 2007 | 01:45 PM
alacard's Avatar
also while we are on the topic, can anyone give me a link to a list of all the necessary parts to bar (lets say) a gsr engine in a 99 hatch. all i know at this point is:
1. engine from the gsr(duh)
2. ecu from the gsr
3. ?
do i need the exhaust from the header back to the muffler? do i even need any of the exhaust parts?
Old Jan 18, 2007 | 01:59 PM
Luserkid's Avatar
Default Re: cali bar (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
and emissions equipment</TD></TR></TABLE>
Actually the year of the motor is top of the list then emission equipment. You could have all the emissions equipment you need to pass but if that motor isnt same year or newer your SOL.
Youll need a CAT, ecu, and all your smog stuff from your pervious motor. Also youll need to wire up the IABs if your going with GSR.
Old Jan 18, 2007 | 02:05 PM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Youll need a CAT, ecu, and all your smog stuff from your pervious motor. Also youll need to wire up the IABs if your going with GSR. </TD></TR></TABLE>
So the cat, ecu, and smog stuff from my original motor will work for the GSR? What about the fact that the d16y7 cat is mounted on the header. would i then need a cat from the gsr?
Old Jan 18, 2007 | 02:58 PM
Luserkid's Avatar
Then youll need a new cat installed after the exhaust. You need a cat either way.
Old Jan 18, 2007 | 04:10 PM
Braco11's Avatar
you need all the smog equipment from a 99 gsr on top of the usdm ecu and a motor at least the same year as your car.
cat should got after the header, like on the gsr. make sure you don't throw any codes. i just BAR'd an h22 in my hatch a few months ago.
Old Jan 18, 2007 | 10:26 PM
alacard's Avatar
thanks for the info guys...still a long ways away, but ill have this for when i need it.
Old Jan 18, 2007 | 10:34 PM
killerB16A's Avatar
Default Re: (alacard)
hey a little tuning will help alot to pass emissions.
Old Jan 18, 2007 | 10:45 PM
B18CivicEH2's Avatar
Default Re: (killerB16A)
can LSVTECs be BARed?
i figure it wouldnt since its a frankenstein motor...just wanna make sure
Old Jan 19, 2007 | 08:56 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote"> hey a little tuning will help alot to pass emissions. </TD></TR></TABLE>
If they want to open your ecu and look for a chip you fail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg &raquo;</TD></TR><TR><TD CLASS="quote">can LSVTECs be BARed?
i figure it wouldnt since its a frankenstein motor...just wanna make sure</TD></TR></TABLE>
No mix matched motors will pass. B18c block with B16 head, wont pass (unless its the ITR block), CRVTEC, LSVTEC, the K series frankenstein.
boozbuster673
12
Sep 26, 2011 08:18 PM
dohc-father
Apr 13, 2007 04:46 AM
dohc-father
Northeast (Sales)
Apr 12, 2007 09:58 AM
alacard
Nov 21, 2006 01:56 PM
jdmcivicsi7
21
Dec 19, 2005 12:14 PM
