need clutch help fast!
Old Jan 18, 2007 | 12:58 PM
j_rohlfing's Avatar
Default need clutch help fast!
i just put a new clutch kit in my 93 lude and my friend told me that i could use 5w-30 for my tranny cuz i didnt have any 10w-30 on hand so we used that and it drove fine last night not beating on it or anything cuz i know it needs to be broke in and then i left it sit for about an hour and it got pretty cold out in between and i drove it home and it started spuddering in between 1000 and 3000 rpms in every gear, plus i can smell the clutch burning...but after that it runs just fine...so i just put 10w-40 in the tranny today and it is still doing it and it is still burning the clutch, any ideas about what is going on??? could my release bearing be the problem cuz i replaced that as well...help on this would be very helpful cuz i dont have a clue and neither do my buddies
Old Jan 18, 2007 | 01:14 PM
john666's Avatar
Default Re: need clutch help fast! (j_rohlfing)
did u resurface the flywheel? it slipping?
Old Jan 18, 2007 | 01:40 PM
j_rohlfing's Avatar
i didnt resurface it, im not sure if it slips but it will spudder untill it hits about 2800-3000 rpms and then it feels like it grabs and go's it doesnt feel like it slips tho...
Old Jan 18, 2007 | 01:42 PM
pprowler6's Avatar
Default Re: need clutch help fast! (john666)
when u put the pressure plate back on did u tighten the bolts to spec? maybe if you tightened them to much it could be causing it to rub all the time...just i thought i could be wrong
Old Jan 18, 2007 | 01:47 PM
j_rohlfing's Avatar
Default Re: need clutch help fast! (pprowler6)
it might be it do you know off hand what the specs would be i just tightened them
Old Jan 18, 2007 | 01:49 PM
pprowler6's Avatar
its suppose to be 19 ft/lbs which isnt much at all
Old Jan 18, 2007 | 01:50 PM
j_rohlfing's Avatar
ya i think i got them on there pretty tight ill check it out thanks for the info
Old Jan 18, 2007 | 01:51 PM
pprowler6's Avatar
Default Re: (j_rohlfing)
yup not a problem
Old Jan 18, 2007 | 01:58 PM
Revi's Avatar
Default Re: (pprowler6)
You need to torque the pressure plate down in a criss cross pattern. If not the pressure plate could not sit against the clutch properly anf cause you problems. If you went ahead and tighten each bolt one by one with out criss crossing you could have un-even contact between the clutch, pressure plate and flywheel.
Also, are you putting in engine oil in the tranny? Or do you mean 10w-30 tranny fluid? You should really put in either Honda MTF or if not GM Syncromesh, thought your problem seems to be clutch instal error.
Old Jan 18, 2007 | 02:12 PM
j_rohlfing's Avatar
are you pretty positive that it is 19 ft/lbs?
Old Jan 18, 2007 | 02:15 PM
pprowler6's Avatar
yea i just double checked in my helms manual. My manual is for a 93 prelude but it shouldnt matter
Old Jan 18, 2007 | 02:27 PM
j_rohlfing's Avatar
alright man thanks a lot ill post again if it works out
Old Jan 18, 2007 | 02:33 PM
pprowler6's Avatar
alirght sounds good
Old Jan 27, 2007 | 05:46 AM
j_rohlfing's Avatar
ok i got it running right now but a slight problem has occured now...when i downshift into 2nd gear it kind of spudders like its not grabbing right any ideas??? it does it somtimes in 1st to like when im taking off
crazihobo
17
May 5, 2010 04:08 PM
roachsboosted16
Transmission & Drivetrain
Jan 9, 2010 04:30 PM
VisPreludeVtec
Sep 8, 2004 12:34 PM
phatintegra
Mar 21, 2002 06:39 PM
phatintegra
Mar 20, 2002 05:56 AM
