Oil Cooler kit Questions?????
i Drive a 1994 Accord EX AT
i was reading about easy upgrades for a car on epinions.com
http://www99.epinions.com/auto...prod5
70$ oil cooler kit? where at O.o only ones i found where like 300 +++!!!
i just need a little more info on this if i am thinking of doing it. considering ive only seen them on turbo'd cars
any good-relatively cheap brands to look into? websites?
the big shiny one is intercooler, which is something else.
I wouldn't put a 70 dollar oil cooler in my car even if you give it to me for a buck fifthy. it only take one poorly make fitting to have your motor seized, don't cheap out on universal kit, and most cheap kit do not put in consideration of PSI, amount of oil and fin effectiviness.
take a look at the fitting on a cheap kit vs. earl's fitting, the quality difference is there, black and white
if you have a realivity stock car, there's no point to have one. According cooling system is more than enought if you are not making alot of power.
I was running boost and my stock cooling system was working just as fine.
did i scare you off yet?
well, there's one good news, that is if you have extra hundred bucks to spend, use them to buy a TRANSMISSION oil cooler, which your auto tranny will thank me later on.
[QUOTE=iam7head
[/QUOTE]
this is truth
[/QUOTE]
this is truth
