o2 sensor 1 wire or 4 wire..already did a search
Old May 15, 2002 | 05:17 PM
1sick4door's Avatar
Default o2 sensor 1 wire or 4 wire..already did a search
92 cx hb...95 sohc vtec motor...would i be able to just use the old o2 sensor(1wire) or do i have to use the 4 wire o2sensor??..if its the 4 wire how do i come about wiring it up?? any info on how to or any sites that show how would be great thanx all
Old May 15, 2002 | 06:02 PM
Jackson's Avatar
Default Re: o2 sensor 1 wire or 4 wire..already did a search (1sick4door)
you have to use the 4 wire sensor if you use the p28 ecu.
Old May 15, 2002 | 06:11 PM
1sick4door's Avatar
Default Re: o2 sensor 1 wire or 4 wire..already did a search (Jackson)
i am using a p28...so how do i come about wiring the 4 wire??thanx for the help
Old May 15, 2002 | 06:13 PM
poison's Avatar
wtf, both are OBD1, d16z6 with p28 is obd1 with a ONE wire o2 sensor. which i believe is green, not sure exactly, i can find out later if u want.
Old May 15, 2002 | 06:17 PM
Jackson's Avatar
Default Re: o2 sensor 1 wire or 4 wire..already did a search (poison)
some weird canadian models came in one wire o2's.
Old May 15, 2002 | 06:22 PM
1sick4door's Avatar
i picked up the motor from a salvage yard..they said it was a 95 sohc vtec motor..it had a 4 wire o2 sensor on it...on the stock motor (92 cx) it had a 1 wire o2..i am running a obd1 p28....anyone??
USDM sI
Sep 13, 2010 03:20 PM
lv6l
Dec 14, 2005 04:04 PM
FBPninetynineEM1
Nov 17, 2003 04:30 PM
mingchi96
Dec 2, 2001 10:38 PM
