obd1 gsr need help wiring engine harness
Old Jan 17, 2007 | 09:17 PM
Olivemyhonda's Avatar
Default obd1 gsr need help wiring engine harness
Well i need help with a obd1 gsr engine harness!
CAR: 95 honda civic ex coupe
MOTOR: obd1 gsr w/obd1 gsr engine wire harness
ECU: obd1 P28 Hondata
The wire harness that i have is pretty much f**ked so im rewiring it for a wire tuck! the plugs for the sensors and other item on the harness that i have are.......
vtec
vtec oil pressure
fan switch
coolant temp (to the cluster)
distributor
engine coolant temp
vehicle speed sensor
ground
starter signal
map
tps
idle air control
intake air temperature
knock
oil pressure
alternator
injector 1
injector 2
injector 3
injector 4
O2 sensor
one sensor that im not going to use is IAB because im not going to use the stock gsr intake manifold! i have a jdm type r manifold!
I have two plugs that have two different wires on them and wondering if anyone can help me!
plug #1
green - black/silver
plug #2
yellow/green - green/black
im not in a rush for a answer! ive been looking @ the ecu pinouts thinking that would help but nothing! well if you cant help me thanks! thanks for your time!
Old Jan 25, 2007 | 09:15 PM
hondude87's Avatar
Default Re: obd1 gsr need help wiring engine harness (Olivemyhonda)
Plug # 2 sounds like a reverse switch plug maybe? Do you have any pics?
Old Jan 26, 2007 | 01:31 PM
Default Re: obd1 gsr need help wiring engine harness (hondude87)
https://honda-tech.com/zerothread?id=1867517
Olivemyhonda
18
Mar 12, 2008 07:22 PM
TGrant
Apr 19, 2006 02:25 PM
Slava.
Mar 23, 2006 03:07 PM
scivicex99
Dec 15, 2004 12:41 PM
Aber
Mar 22, 2004 08:32 AM
