auto to cable tranny swap.
Old Jan 17, 2007 | 07:24 PM
Maxboost00's Avatar
Default auto to cable tranny swap.
I just a 90 crx that auto and i wanna swap it to a manual cable tranny and jus use the car as a fun daily driver. Do any u guys know what parts i need to do the swap or of any other sources of info that may aid me in the swap thanks in advance.
Old Jan 17, 2007 | 07:28 PM
s10cky's Avatar
Default Re: auto to cable tranny swap. (Maxboost00)
Easy swap, ive done it in a day.
Drill two holes, they are allready marked on the floor board where the stabilizer bar bolts.
Get the shift linkage, get the clutch cable, and get the clutch and gas pedal assembly off of a manual car.
There is allready a hole in the firewall for the clutch cable, run the cable through to your new cable trans. There are some wire modifications that are needed, one is two basically convince the ecu the car is in park so you can get your keys out. Do a search on that, there are like 2 or 3 different websites that show detailed instructions.
Its way easy.
AndrewGoPro
Aug 23, 2017 01:45 PM
be8teensee1
May 17, 2009 09:18 PM
AJZerick
Jan 28, 2008 05:19 PM
hb_guy
Oct 31, 2005 03:43 AM
