does anybody have a 99-00 civic ex
does any one have a 99-00 with power windows
i need to see if my switches are bad will pay
needs to be close to montebello california 323 636 562 213
hit me up asap
hit me up asap
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
take off the door panel find the wire going into the motor that push's the window up and strip some of it take a hot wire touch it to make it go up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">thanks alot **** hole now both of my windows dont roll up wtf!!!!!!!!!</TD></TR></TABLE>
You could be spending all this time "bumping" and ****...searching for diagrams. If I run a 30 second search and find the answer to your question...I will kidnap your first born!
EDIT: First things first, check ALL your fuses in both the engine bay fuse box, as well as the dash box. After all your fuses are good, make sure all of your connections are correct and there is no "reverse polarity" going on. Make sure none of the wires are cut and/or grounding out. Connect everthing back to the way it was before you started ******' with things and make sure everything works correctly again. After that.....follow these threads and do things the correct way. I really can't think of any other way to help you online...
https://honda-tech.com/zerothread?id=1140490
https://honda-tech.com/zerothread?id=1762783
Good luck!
Modified by I Shot 50 Cent at 5:41 AM 1/18/2007
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent »</TD></TR><TR><TD CLASS="quote">
Good luck!
Modified by I Shot 50 Cent at 5:41 AM 1/18/2007</TD></TR></TABLE>
well i did follow the exact same diagram that u showed me the second link
and it worked for the pass. side but for the driver side it only ticks when pushing in the down position.
and this dumb *** said to hot wire it from the main wires wich he said was only two and there was blue red black and yellow.so i tried the yellow and it shorted out my pass side window now that side only rolls down and i cant do anything now.
Good luck!
I understand you're frustrated but I wouldnt call Throwdown a dumbass. He knows his **** for sure. And ironically...you DID go out there and try it because someone from Honda-Tech said it works...so if HE's going down for being a dumbass...he's taking you with him.
You also may not have done exactly what he was trying to explain, yanno?
****'ll work out man, keep your head up.
</TD></TR></TABLE>I understand you're frustrated but I wouldnt call Throwdown a dumbass. He knows his **** for sure. And ironically...you DID go out there and try it because someone from Honda-Tech said it works...so if HE's going down for being a dumbass...he's taking you with him.
You also may not have done exactly what he was trying to explain, yanno?****'ll work out man, keep your head up.
I know for a fact he didnt do it right. All you need is a multimeter to find out which wire to hot wire. Its not our fault your trying to do something that you should be doing. If you can even figure that out, you need to take you car to the scrap yard.
well i didnt have a multimeter and there are four wires to the motor and two thick wires so i went after one of them and something definitly burned because a little puff of smoke
went out. but what i dont understand is how can that mess up the pass side door
please give me some suggestions. i already checked all the fuses all the wires i did wire by wire so i know there all correct. the only thing i can think of myself is that the main switches went out and only work going down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">but i also bought these foors here on ht so maybe the door just doesnt work</TD></TR></TABLE>
Even if they DID work...after that little puff of smoke, they definitely don't anymore! Did you check fuses after that happened? Lets hope that the fuse is the only damage.
