Milleage gauge not moving...need help smog soon
Old Jan 17, 2007 | 05:20 PM
k_lude's Avatar
Default Milleage gauge not moving...need help smog soon
alrite my car is fine but the gauge for my mileage has stopped..i need to get it fixed before i smogg it.....can someone help or give posiblities i can look into...
Old Jan 17, 2007 | 06:57 PM
k_lude's Avatar
Default Re: Milleage gauge not moving...need help smog soon (k_lude)
help..im due to smog
Old Jan 17, 2007 | 06:59 PM
PreludeRacing247's Avatar
does your speedo work, what year model is your car
Old Jan 17, 2007 | 07:00 PM
k_lude's Avatar
Default Re: Milleage gauge not moving...need help smog soon (PreludeRacing247)
5th gen....1998...yes all gauges work except for the mileage one its stuck and wont flip over...mileage in the 14xxxx
Old Jan 17, 2007 | 07:04 PM
Ok if i make no mistake im sure it runs off of cable just like the 3rd and 4th gens not really sure the only thing i know to do is to take your pod out and make sure all conections are good and nothing is broken.
Old Jan 17, 2007 | 07:07 PM
k_lude's Avatar
i was thinking that also, but one of my mechanic buddys that i take my car to said it might be something from the tranny...like a sensor...he has worked on cars for over 10 years and mostly imports....so i trust him...even though i dont wanna pay to get a little thing like this fixed though..i just need something i can work with...i will however get the pod checked out though by this weekend..
Old Jan 17, 2007 | 07:10 PM
ok man good luck to you
Old Jan 17, 2007 | 08:24 PM
hamadiscool's Avatar
Its called a VSS. Vehicle speed sensor. If you speedometer also sometimes doesnt work then that might be what is wrong. Mine broke not too long ago, I had a spare tranny lying around so no problem for me . Good luck buddY!
Old Jan 17, 2007 | 09:05 PM
k_lude's Avatar
Default Re: Milleage gauge not moving...need help smog soon (hamadiscool)
hold on...my speedometer never has had anything wrong with it...so are u saying i would need a whole new tranning or just the VSS also were is it located..can i see it from the top of the motor...or is it inside the tranny itself..
Old Jan 17, 2007 | 10:43 PM
pprowler6's Avatar
looking down at the engine from the front the vss is closest to the firewall on the tranny. it has a wire plugged into the top and 2 rubber hoses coming out from it for power steering.
Old Jan 18, 2007 | 05:07 AM
Iboot's Avatar
Pull it out like so http://www.ntpog.org/mods/fift...shtml it takes 5 mins. If everything is hooked up then you can proceed busting your ***** with the VSS. What i would do is go to a local junkyard and pull a new one out.
Old Jan 18, 2007 | 07:09 AM
professorman's Avatar
Default Re: (Iboot)
My mileage guage had stopped working on my accord while I was on a 5hr trip. I realized that it was because I had pushed my key into the slot to reset the maintenance indicator light. I pushed the key in there again and it started working again. Apparently, it was not pressed down full the first time I pressed it and had gotten stuck.
Old Jan 18, 2007 | 07:26 AM
k_lude's Avatar
Default Re: (profroopchan)
ill go try the maintenance key thing first then pull out the cluster...if its not both then I guess ill have to check out the VSS
Old Jan 18, 2007 | 02:38 PM
k_lude's Avatar
shoot..thanks profroochan...it worked...thanks everyone
ChrisJDM
Transmission & Drivetrain
Feb 13, 2013 06:06 PM
darylfiend11
Jul 8, 2004 12:03 PM
Full Race A6
Jun 24, 2004 02:33 PM
brirup
Dec 30, 2003 10:22 PM
aznfab
Aug 23, 2003 02:59 PM
