white thick fluid came out of tranny yesterday!!!
Old Jan 17, 2007 | 05:01 PM
ilovejdmhoes23's Avatar
Default white oil was inside my transmision???
i was taking an axle out of my transmision when all of a sudden white oil came spilling out and alot came out! so does any1 know what it is? and has it happened to any one else? iam going to drain the rest of the fluid and put new oil!
Modified by ilovejdmhoes23 at 6:11 PM 1/17/2007
Old Jan 17, 2007 | 05:05 PM
over_'s Avatar
Default Re: white thick fluid came out of tranny yesterday!!! (ilovejdmhoes23)
maybe we should start with how you define "tranny", and "axle".......
nicko360's Avatar
* B A N N E D *
i think your tranny had an orgasm
Old Jan 17, 2007 | 05:37 PM
Shaun_'s Avatar
Have you been doing something you shouldn't be with your trans?
Old Jan 17, 2007 | 05:44 PM
nicko360's Avatar
* B A N N E D *
Default Re: (Shaun_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun_ &raquo;</TD></TR><TR><TD CLASS="quote">Have you been doing something you shouldn't be with your trans?</TD></TR></TABLE>
yeah man I think you've been stroking that axel too much
Old Jan 17, 2007 | 05:49 PM
sohc_coupe24's Avatar
Default Re: white thick fluid came out of tranny yesterday!!! (nicko360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">i think your tranny had an orgasm</TD></TR></TABLE>
ahahaahhaah..hilarious
Old Jan 17, 2007 | 05:51 PM
egmatt93's Avatar
Default Re: (nicko360)
yeah man I think you've been stroking that axel too much</TD></TR></TABLE>LMAO!
Old Jan 17, 2007 | 06:00 PM
Crx Jimmy's Avatar
Default Re: white oil was inside my transmision??? (ilovejdmhoes23)
no really, you somehow got water inside the transmission and all the gears spinning inside turned it into a milkshake. I have seen this in engine oil as well. drain, refill with some cheap motor oil run it for a couple miles, drain and put some real honda mtf in. that should get most of it out
Old Jan 17, 2007 | 06:10 PM
solerizr's Avatar
Default Re: white oil was inside my transmision??? (Crx Jimmy)
And fix the leak, or it will happen again. My guess is the VSS isnt sealing correctly.
hammergunner
Sep 11, 2008 08:00 PM
invisible
Mar 11, 2007 09:35 PM
Discontained
22
Oct 16, 2006 02:07 AM
Nyris
17
Oct 11, 2005 11:40 AM
92hondalude
Jan 10, 2005 11:19 PM
