CODE 16
i go to drive mah car and give it hard gas the tires spin up slammed it to 2nd spinning and hook 3rd then the car starts to bogg out and den CEL comes on and i check it and it says code 16 and the car wont rev over 3,500 RPM and code 16 is fuel injectors i mean what could it be from the fuel injectors?
That code sets when there is a break in the electrical path for the injectors. Basically... battery-ign switch-main relay-injector coils... plus all the wiring and clips in between. (BTW, the injectors are constantly fed power. The ECU grounds them to pulse them)
so i can js reset the whole car and hopefully it was js on because of something touching or malfunctioning or something? or its something i have to check out or fix?
93LsVx
Aug 28, 2010 09:20 AM
