What to look out for in a 93 del sol si?
Any problems to look out for in a 93 del sol si? I will be taking a look at one with 100k miles, clean title, original owner and all stock. let me know. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeice30 »</TD></TR><TR><TD CLASS="quote">Any problems to look out for in a 93 del sol si? I will be taking a look at one with 100k miles, clean title, original owner and all stock. let me know. thanks!
The same stuff with most civics, main relay, engine sounds, transmission grinds, etc
Also, leaks. Roof leaks, trunk leaks, cancer, etc. The roof seals love to leak, and the trunk likes to leak. Look everywhere for cancer.
The door panel vinyl bubbles up on all of them, and any piece of hinged plastic (glove box, stereo cover, ashtray) is subject to be busted. Other than the leaks and interior stuff, they're pretty much like any other Civic.
</TD></TR></TABLE>The same stuff with most civics, main relay, engine sounds, transmission grinds, etc
Also check for function on the power windows and mirrors. Also the aux lights like to bust. Make sure the roof mounts and removes properly. Check the roof rack in the trunk to make sure it works. If not, it's just some pneumatic cylinders.
If it's a one owner car and not abused, it's probably not going to be a big issue. You're mostly looking at little headaches with a Del Sol, and most of those are cheap and/or easy to fix.
85_305
32
Nov 11, 2008 08:25 AM
NVMYSi
May 28, 2005 07:04 AM
