gsr swapped
Old Jan 17, 2007 | 01:42 PM
slimjimdanny's Avatar
Default gsr swapped
hey i have a gsr swap 92 w/ a 94 motor .. the gsr motor is in a 92 hatchback vx.. i got it done professional at 1320 custom fab.. and was hoping if that would pass smog and reffing.. anywase how do they reff.. what do they do when they reff your car?
Old Jan 17, 2007 | 01:44 PM
I Shot 50 Cent's Avatar
I believe there's a thread that lists completely what happens when you take your car to a California Smog Ref. Its actually a really interesting thread....try to search around and find it, and i'll do the same. If I find it...i'll edit this post and give it to you.
Good luck!
EDIT: I searched and got too many results to even post! Click search, then search "Cali Smog" and select to search in the "archived threads", and have fun reading! I guarantee you'll be able to answer ALL of the questions you'll have on this topic.
Old Jan 17, 2007 | 01:56 PM
doood's Avatar
been there done that
Default Re: (I Shot 50 Cent)
all the emissions equipment must be hooked up and working with no CEL's. then you can take it to be bar'ed. once it's bar'ed it'll be legit. that's how it is with my b18c1 swapped 95 coupe.
i bought my car with all this already done so i couldnt tell you how the process is.
Old Jan 17, 2007 | 05:46 PM
jay_cue's Avatar
Default Re: (doood)
Just call to schedule an appointment at 800-622-7733. You basically go to a state smog station. They do a visual test to make sure all smog equipment is on. Then do a tailpipe emmissions test. If everything passes they put a sticker on your that says you have a different motor in the car
Old Jan 17, 2007 | 06:12 PM
Default Re: (whal3_p3nis)
thanks guys.. i really needed the number.. im going to one on the 22nd.. there is no check lights so hopefully nothing happens
Old Jan 17, 2007 | 07:09 PM
Default Re: (slimjimdanny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slimjimdanny &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys.. i really needed the number.. im going to one on the 22nd.. there is no check lights so hopefully nothing happens
Good luck brotha!
JDM EK-R
Mar 6, 2008 12:40 PM
EK9Tune
Jul 7, 2007 11:42 PM
bleezfome
Jun 2, 2006 08:04 PM
tongman
Feb 20, 2005 10:53 PM
Dyn0speed
Jun 26, 2004 05:27 PM
