Release Fork
Old Jan 17, 2007 | 01:03 PM
mc's Avatar
mc
Default Release Fork
Is it possible to remove and replace the release fork without removing the tranny? I thought I had a problem with my slave cylinder and replaced that but after looking closer I realized the release fork is just wobbling around inside the tranny. I am thinking about pulling the radiator to make room so I can get a closer look at what exactly the problem is and see if I can set it back into place, but am not sure if I will just be wasting my time and delaying the inevitable of removing the tranny.
TIA
Old Jan 17, 2007 | 03:24 PM
Bense's Avatar
there's a spring that holds it onto the "ball" once it's preloaded with pressure from the hydraulic system it should line up in place.
I doubt theres a way do this w/o removing the trans.
Old Jan 17, 2007 | 04:58 PM
Tzer's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">there's a spring that holds it onto the "ball" once it's preloaded with pressure from the hydraulic system it should line up in place.
I doubt theres a way do this w/o removing the trans. </TD></TR></TABLE>
You might have what I ran into. The pivot "Ball" broke and I couldn't shift into gears. I did the same, got a new slave and while replacing it I was able to pull the fork right out of the clutch housing.
Bense is right. your probably going to have to remove the trans.
Good luck on your repair.
Tzer
Ldo
Sep 16, 2008 12:20 PM
D-meet07
Jul 21, 2007 02:14 PM
yoffer
15
Apr 25, 2007 06:58 PM
komat
Apr 30, 2005 06:38 AM
xpracing
Jan 24, 2002 06:25 PM
