92 Civic Hatch Speaker Question
Old Jan 17, 2007 | 12:33 PM
truevietluv636's Avatar
Default 92 Civic Hatch Speaker Question
i pulled out my door panel and was in the process of replacing my front speakers but they dont fit. my speaker is 6.5's and so are the old ones, but the speaker holder is still too small for my new speakers. anyone know if there is any different speaker holders for my car or do i have to drill the new speakers into the door.
Old Jan 17, 2007 | 12:49 PM
platinumx6's Avatar
Default Re: 92 Civic Hatch Speaker Question (truevietluv636)
i thougth they where 5 1/2"s?
You could make a custom mount with some plywood..
Old Jan 17, 2007 | 12:50 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">i pulled out my door panel and was in the process of replacing my front speakers but they dont fit. my speaker is 6.5's and so are the old ones, but the speaker holder is still too small for my new speakers. anyone know if there is any different speaker holders for my car or do i have to drill the new speakers into the door.</TD></TR></TABLE>
some one corrct me if i am wrong, but i thought the speakers in the front were
5 1/4". this maybe your problem.
Old Jan 17, 2007 | 12:59 PM
well my front ones are aftermarket 6.5's but as i doulbe checked my oem plastic mounts, the opening is only 5'. this sucks, i've done a search about speaker sizes and crutchfield says 6.5's in the front. i think i'll have to custom some wood mounts, but before i do, could anyone who has 6.5's tell me how they did it. a pic of the mount would be great.
did anyone ever try cutting the plastic backing pieces of the oem mounts to fit some 6.5's?
this is what i got....
Old Jan 17, 2007 | 01:21 PM
philosofy1's Avatar
yeah, if you want to use those oem brackets, then you are going to need 5.25" speakers. yes crutchfield does say 6.5", but technically they are wrong. you can fit 6.5, but you are going to have to make something up so it can work.
Old Jan 17, 2007 | 01:29 PM
platinumx6's Avatar
Default Re: 92 Civic Hatch Speaker Question (philosofy1)
i ment 1/4.
Yes that should work.
Old Jan 17, 2007 | 01:36 PM
thanks for the info, i guess i'll try exchanging my 6.5s for a 5.25.
Old Jan 17, 2007 | 01:38 PM
kuja396's Avatar
Default Re: 92 Civic Hatch Speaker Question (platinumx6)
Im 99% sure that the front speakers in my coupe and hatch are 6.5 inches. To get then mine to fit i had to cut the back of the speaker bracket (from the car) off. Give me some time to check/post a pic.
I Shot 50 Cent's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info, i guess i'll try exchanging my 6.5s for a 5.25. </TD></TR></TABLE>
No, I have 6.5's in my front doors. Just get a dremel or a utility knife and "hack" up that stock peice until they fit. Just beware that some of the higher end models of speakers have a deeper magnet, and they may hit the window track. If this happens...just make a 1/4" baffle to bring the speakers out further from the regular mounting location.
It is certainly possible to put 6.5's there with minimal effort. Just look @ the locations closely, and I'm sure you can use common sense to get them to fit. Good luck man! Think positive! haha...because its definitely possible.
Old Jan 17, 2007 | 03:52 PM
Default Re: 92 Civic Hatch Speaker Question (I Shot 50 Cent)
you guys got any pics of the cut up stock piece? i got a dremel so it would be an easy job but i want to see if there is any possible way to do a very clean looking job.
Old Jan 17, 2007 | 06:28 PM
smokerz212's Avatar
im 99%sure that my speaker is 6 1/2 and its pioneer the blue one.. my gf bought it for me this christmas and i used that black plstic.. fit with no prob!
Old Jan 17, 2007 | 06:39 PM
92ehatch's Avatar
Default Re: 92 Civic Hatch Speaker Question (smokerz212)
i have ALWAYS put 6.5 in in all my civics. 4 of them to be exact
cut the backing of the plastic away. and then you should be able to fit it.
some of the speakers come with adapters as well.
but iver never had a problem putting in 6.5
and when i buy new speakers for this hatch, 6.5 they will be
Old Jan 17, 2007 | 06:54 PM
allricedout's Avatar
for me i took out the stockers, and managed to put 6.5's in secured by only 2 screws (that were angled sideways) and with a spacer. without the spacer the mag's would hit the door.
Modified by allricedout at 8:14 PM 1/17/2007
Old Jan 17, 2007 | 06:59 PM
jadugartir's Avatar
The reason it wont fit is because the back plate on the stock mount is too shallow. So i took a dremel to it and cut off the back plate. Now i can fit any 6.5's i want.
Old Jan 17, 2007 | 07:03 PM
CXtypeR's Avatar
Default Re: 92 Civic Hatch Speaker Question (jadugartir)
would it matter if the "magnet" piece of the speaker is laying right on that plastic stock bracket???
Old Jan 17, 2007 | 07:19 PM
bpr0422's Avatar
6.5" is the outer diameter.....
the inner opening is 5".. and most 6.5" speakers have 5" inner diameters...
the ones that don't are the Oversized 6.5"
to get around that, build a new bracket... or find one... my polk 6.5" speakers came with OS 6.5" speaker brackets...
now if the speaker is sticking out.. you might just have to cut the back of the plastic out...
Old Jan 17, 2007 | 07:38 PM
Built Beast's Avatar
Flip that black stock piece over...
Stomp on it, (SERIOUSLY, it will break the back plastic without hurting the mounting bracket).
Then, mount your 6.5 in there... works everytime. That is what I have always done. Of course, you can always dremel it as others suggested.
Same outcome!
Old Jan 18, 2007 | 06:26 AM
Default Re: 92 Civic Hatch Speaker Question (Built Beast)
i think im going to take a dremel and cut the back pieces. the only problem is that my kenwood 6.5's has a small lip behind the speaker so it doesnt fit through the 5' hole of the oem piece... you guys know if infinity 6.5's fit? i got a hookup on those and probably putting 6.5's w/ tweeters in the front and 5.25's in the back.
Old Jan 18, 2007 | 03:23 PM
Yes Infinity perfect 6.5s work in there, I have put those in a friend's car before (93 civic ex). Do the dremel way if you would like, but honestly, my way works the same, without making a mess.
Old Jan 18, 2007 | 07:07 PM
badm0j0's Avatar
I've had Infinity and Boston 6.5's in their. cut the basket out and through some foam baffles in and you're good
Old Jan 24, 2007 | 05:09 PM
Default Re:
i just cut the mounts earlier today. new infinity 6.5's fit perfect. thanks for all the info.
now about the rears... anyone know how to make them 6.5's? i got the metal brackets that the speakers bolt onto. looks like its almost a good fit, except they're like 1cm too small. anyone ever do a custom for 6.5's or 6x9's. anyone ever shave the metal brackets... if you guys did let me know how.
Old Jan 24, 2007 | 06:26 PM
JSPECSIR's Avatar
Default Re: Re: (truevietluv636)
put alpine type s mounting rings on there and the 6.5s will fit the rear brackets then. any shop or best buy that sells alpine should have tons of those alpine rings left over. philosophy, your right and wrong sort of. civics are easy, if it has the plastic mounts pictured above (usualy ex/si) in the door it fits a 6.5, if the speaker mounts directly to the door metal (usually cx/dx) it fits a 5.25. hope this helps.
Old Jan 24, 2007 | 06:40 PM
hondanut's Avatar
Default Re: Re: (JSPECSIR)
MY CAR HAS 6.5 IN FRONT SONY MAKES THE REPLACEMENTS YOU CAN CUT THE BACK OUT TOO GET A LONGER SPEAKER IN
Old Jan 24, 2007 | 06:52 PM
H22Ej1's Avatar
Shenanigans
Default Re: Re: (hondanut)
i installed 6.5 inch alpines in the front and used the adapters they came with...works perfect
Old Jan 25, 2007 | 06:50 AM
Default Re: Re:
Im already done with the fronts..... Just need information on the rear. Are you saying that if i get alpine type s mounting rings, i could mount 6.5's on the rear metal brackets? and how would i cut the rear metal brackets? (i got a vx hatch)
