Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 CRV EX clunk when making a hard left turn
Old Jan 17, 2007 | 11:57 AM
underpressure02's Avatar
Default 2003 CRV EX clunk when making a hard left turn
My coworker asked me to come out and listen to this noise she is having in her CRV. She said it would clunk when she turned to the left I thought maybe a cv was going bad. I took the car for a ride and the clunk appears to be coming from the tunnel almost like the exhaust is hitting something hollow. I can only get it to happen if I am moving and turn the car to the right and left very fast it will keep on reproducing the noise. Otherwise it will only do it once in a while. I did not get to crawl under the car being that I am dressed in a suit but I was just wondering if there are any known problems.
TIA
Old Jan 17, 2007 | 12:14 PM
Sly_Samba's Avatar
HTBATRACER
Most likely the rear differential fluid needs to be changed. That will produce a clunking noise from the rear end.
Old Jan 17, 2007 | 12:27 PM
Default Re: (Sly_Samba)
It is coming from the front middle part of the car not the rear and will only do it when turning hard left or if you turn hard left and right really fast.
Old Jan 18, 2007 | 02:56 AM
Ross 2.0's Avatar
In a Junkyard near you.
usually when it makes a noise like that the car has run over something. So you need to peek under it to see if anything is bent or broken
Old Jan 18, 2007 | 02:58 AM
Ross 2.0's Avatar
there is also a bulliten for noise when turning left. PM me with your email address and I can send it to you
Old Jan 21, 2007 | 04:29 PM
Default Re: (Ross 4107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 &raquo;</TD></TR><TR><TD CLASS="quote">there is also a bulliten for noise when turning left. PM me with your email address and I can send it to you</TD></TR></TABLE>
Sent you a pm last week did you get it?
motegicivic
Jul 13, 2011 03:42 PM
turbotime
May 6, 2007 03:21 PM
pepper2
Aug 22, 2006 09:41 PM
Striker
Feb 1, 2002 02:56 PM
