Camberkit /casterkit honda del sol
Old Jan 17, 2007 | 11:15 AM
dels's Avatar
Default Camberkit /casterkit honda del sol
Anyone know where it is possible to get a cheap caster/camber kit for a Honda EH6 del sol?
Old Jan 17, 2007 | 11:17 AM
Eran's Avatar
HT White Ops
You can't buy caster kits, but camber kits are easy to find. Are you in Oslo, as in Sweden?
Old Jan 17, 2007 | 12:15 PM
dels's Avatar
Norway But what can i do about the caster then?
Old Jan 17, 2007 | 12:29 PM
Eran's Avatar
HT White Ops
Default Re: (dels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dels &raquo;</TD></TR><TR><TD CLASS="quote">Norway But what can i do about the caster then?</TD></TR></TABLE>
Your caster should not be off. If it is, you need an alignment. If it's still off, you have some bent suspension pieces.
Old Jan 17, 2007 | 01:51 PM
dels's Avatar
Results from the test, is it possible to do something with this?
Caster Front right -0.07 min: 0.10
Camber front left -1.12 min: -1
Camber front right -1.42 min -1
Old Jan 17, 2007 | 01:52 PM
Mario_D's Avatar
Default Re: (dels)
Was the vehicle ever in an accident? Or did it recent go curb hunting? Moving the ***** that far from spec is something to be concerned about.
m-
Old Jan 17, 2007 | 02:23 PM
dels's Avatar
Just bought the car! it has 30mm H&R lowering springs. Is it that bad?
Old Jan 17, 2007 | 02:51 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (dels)
fix your toe, forget about your camber. You bought the suspension kit to improve handling. Camber that will result from that much lowering (about 1.25 inch) will be beneficial. Camber does not wear out tires (only a negligible amount). Toe wears out tires. You're probably only going to have -1 to -1.5 degrees of camber. I would run like -2.5 and -3.0 on my hatchbox when i had it, and wore out tires completely evenly as long as my toe was straight. Trust me on that one.
Old Jan 17, 2007 | 02:58 PM
dels's Avatar
OK, but i need to have to fix the camber and caster in order to get the car registered by the authorities in my country :/
Old Jan 17, 2007 | 04:15 PM
B serious's Avatar
Default Re: (dels)
ORLY?!! lol thats right i forgot about european laws of alignment. Yeah get a camber kit. Your caster will start to fix itself as the camber comes back in because the control arms articulate.
Old Jan 17, 2007 | 04:32 PM
dels's Avatar
thank you
marcelosm
Nov 24, 2014 07:58 AM
pacothetaco
Suspension & Brakes
Sep 15, 2012 10:35 AM
saveacivic
Sep 15, 2007 04:11 PM
SomeGoodBud2
Suspension & Brakes
Feb 15, 2007 12:59 PM
Phaze2 Mike
Dec 25, 2002 06:12 AM
