Putting a new cat in my 5th prelude... any advie/tips?
Old Jan 17, 2007 | 09:44 AM
Ideal's Avatar
Default Putting a new cat in my 5th prelude... any advie/tips?
Just like the topic states, my cat went bad so im putting my new one in today... any advice or tips?
Old Jan 17, 2007 | 09:47 AM
Revi's Avatar
Default Re: Putting a new cat in my 5th prelude... any advie/tips? (Ideal)
Soak the nuts in WD40 or in some kind of rust eater. Those nuts can be welded on there from all the rust and heat over the years.
Soak them overnight, work on it in the morning.
Old Jan 17, 2007 | 10:00 AM
GO-FIGHT-KILL's Avatar
^ Best advice.
Try some PB Blaster too.
Old Jan 17, 2007 | 11:00 AM
M2B4's Avatar
Default Re: (GO-FIGHT-KILL)
soak em and use 6 pt sockets
Old Jan 17, 2007 | 11:31 AM
VTECnKEN's Avatar
Feed it and give it a litterbox this time.
But seriously, did your catalytic converter go bad due to age or was it random?
If it was due to a problem, the new cat could fail for the same reason as the last one. Just wanted to check, let us know.
Old Jan 17, 2007 | 12:12 PM
Ideal's Avatar
Default Re: Putting a new cat in my 5th prelude... any advie/tips? (VTECnKEN)
well my car has been running rich and has had some blow-by so im assuming that my 02 sensor is out to, so i am replacing both, im really hoping that will fix the problem. I know that cat is bad because its rattling like a mother.
-Jon
Old Jan 17, 2007 | 01:42 PM
KEVLARsh's Avatar
just be careful w/ the bolts and nuts, spray them good like the others said
Old Jan 17, 2007 | 01:44 PM
scootertribe's Avatar
Default Re: Putting a new cat in my 5th prelude... any advie/tips? (DK-Kip)
Yeah, I ran rich for too long and blew a friggin' hole right through my old cat...Threw the code so i got a new magnaflow put in too. Sensor was ok it seemed. Good luck.
92eghb
May 15, 2012 05:29 AM
mortificationrock
12
Jan 28, 2010 12:09 PM
mrspeedy69
15
Jun 13, 2009 06:09 PM
Token Blk Guy
Sep 14, 2002 10:46 AM
93delsol
Apr 4, 2002 01:03 PM
