Mini-Me vs ZC
Old Jan 17, 2007 | 07:20 AM
Grandhustleman86's Avatar
Default Mini-Me vs ZC
honda's are not powerhouses(OEM)....with exceptions H-K series which run $$$$....so in my lil delimma im needing to run with what Iv'e got...Question is simply this: A built Sohc(cam + pully, forged pistons, forged rods) OR built ZC (Cam'S + pully'S, Forged pistons, forged rods)....Both are running 10-13LBS. on a T3 GT-10 with metal headgaskets....with expericend owners what is (or was) the best decision for the Dseries gurus....
Old Jan 17, 2007 | 10:24 AM
Akiraboy's Avatar
Default Re: Mini-Me vs ZC (Grandhustleman86)
Not being technical on this answer:
the single slam has more options since it saw higher production numbers and had more aftermarket support (here in the US) than the dohc zc. Sohc interchangability between obd 0,1,2 platforms is a plus. Mini-me ect. Simplicity.
The dohc zc imho makes a great high rev machine with the right cams, head, valvetrain, & itbs
I've personally owned both but only boosted the single cam
search H-T, sohchonda.com, d-series. org, thezcresource.com and homemadeturbo.com
you'll see quite a mix of turbo single cams & dohc zcs
p.s.
liam 821 on this board built a real potent dohc zc some years back. If I were to build one... it would model his
Old Jan 17, 2007 | 01:52 PM
crxnj's Avatar
Default Re: Mini-Me vs ZC (Akiraboy)
^^ did you just say the dohc zc makes a good rev machine?
The only d-series ive seen that likes to be revved is the d15b vtec.
dohc zc's hate to be revved.
Old Jan 18, 2007 | 07:26 AM
Akiraboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akiraboy &raquo;</TD></TR><TR><TD CLASS="quote">Not being technical on this answer:
The dohc zc <FONT COLOR="red">imho</FONT> <U>makes</U> a great high rev machine with the right cams, head, valvetrain, & itbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">^^ did you just say the dohc zc makes a good rev machine? </TD></TR></TABLE>
the quote speakes for itself
dohc zc's hate to be revved.</TD></TR></TABLE>
Your entitled to your opinion, so am I.
Old Jan 18, 2007 | 07:40 AM
HumanResource's Avatar
D SOHCs are more prone to blowing headgaskets when improperly set-up, i.e. too much boost, not enough enough tuning.
When you're playing with boost, you only need to "rev" ENOUGH.
Old Jan 18, 2007 | 07:46 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: Mini-Me vs ZC (HumanResource)
Mini Mes bump stock compression generally speaking. SO... you need to look into lower compression pistons or a thicker head gasket to compensate.
that being said... i dont have either... i've just done alot of homework on the mini me. none of the ZCs that my friends have had held up to NA abuse on road coarses... so i never thought of it as an option.
Old Jan 18, 2007 | 09:23 AM
crawfo661's Avatar
Default Re: Mini-Me vs ZC (Kaan)
mini me swaps are better for NOS, zc better for boost, my opinoin of course
Old Jan 18, 2007 | 09:49 AM
dohc_profile's Avatar
Default Re: Mini-Me vs ZC (mr.speaker)
id agree with mr. speaker, ive seen the d15b vtec get the **** revved out of it and the powerband lasted pretty long. it was brought up to 8 grand by the owner many times and still runs strong.
Old Jan 18, 2007 | 09:51 AM
b16er's Avatar
Default Re: Mini-Me vs ZC (dseries_ef)
Man this is comparing poo to pee. Either way, they smell.
Old Jan 18, 2007 | 08:40 PM
crawfo661's Avatar
Default Re: Mini-Me vs ZC (b16er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16er &raquo;</TD></TR><TR><TD CLASS="quote">Man this is comparing poo to pee. Either way, they smell.</TD></TR></TABLE> ur probably runnin a b that any d will smoke brother, don't hate, help
Old Jan 19, 2007 | 09:09 PM
crxnj's Avatar
Default Re: Mini-Me vs ZC (crawfo661)
No,I meant the actual bottem end ,it doesn't like to be revved at all. I've replaced alot of bearings and crankshafts in those motors ,and people only took them a bit over 7000revs..
But with the d15b vtec, it revs like a b16a..
Old Jan 20, 2007 | 08:49 AM
SIred91's Avatar
Rainman
Speaker is correct.
You youngsters gots to thinks more before you rev something.
ITS CALLED ROD/STROKE RATIO. D engines other than the d15 CANNOT handle revving past the stock cut out, its there for a reason.
Old Jan 20, 2007 | 12:22 PM
jdmb161gen's Avatar
dohc zc are better than sohc i have a full built zc with full race turbo kit in my 1990 honda crx si it ran 12.78
Old Jan 20, 2007 | 12:42 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandhustleman86 &raquo;</TD></TR><TR><TD CLASS="quote">honda's are not powerhouses(OEM)....with exceptions H-K series which run $$$$....so in my lil delimma im needing to run with what Iv'e got...Question is simply this: A built Sohc(cam + pully, forged pistons, forged rods) OR built ZC (Cam'S + pully'S, Forged pistons, forged rods)....Both are running 10-13LBS. on a T3 GT-10 with metal headgaskets....with expericend owners what is (or was) the best decision for the Dseries gurus....</TD></TR></TABLE>
WTF!?
you can afford a turbo kit, and forged internals, but think that H series are $$$$ ???
keep your eyes open partner.
BTW, bench racing and bench dyno tuning are GAY! any motor with a turbo will make power. a sohc and a zc will make about the same power..... its all up to you and the availability of parts.
/ thread
Old Jan 20, 2007 | 01:14 PM
crxnj's Avatar
Default Re: Mini-Me vs ZC (jdmb161gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb161gen &raquo;</TD></TR><TR><TD CLASS="quote">dohc zc are better than sohc i have a full built zc with full race turbo kit in my 1990 honda crx si it ran 12.78 </TD></TR></TABLE>
so how does that make the dohc better? you can run 12's with a sohc to.
dohc_zc_build
Sep 3, 2013 02:43 AM
alx_90ef
Mar 27, 2009 06:20 AM
bacnoonoi
16
Oct 3, 2008 08:36 AM
torquelessss
Aug 22, 2006 06:39 PM
redzcstandardhatch
74
Dec 15, 2003 08:17 PM
