how to get good color in tig welding
Old Jan 17, 2007 | 06:54 AM
crxsir23's Avatar
Default how to get good color in tig welding
iv seen some pepole in here tig and get this reddish coloring in their welds i can get good penetration and be Consistent with my welds but cant get that coloring the only way i can even come close is on ac and i have gas lenses also
Old Jan 17, 2007 | 09:55 AM
shortyz21's Avatar
Default Re: how to get good color in tig welding (crxsir23)
u get good coloring when your amperage is dialed in really good, and you move fast.
colors are just for looks, most guys will run a "fancy pass" on their weld to make it look like that.
if you wire brush your weld and u got no pitting or oxidation, its going to be just as strong as some colored weld..
Old Jan 18, 2007 | 04:37 AM
crxsir23's Avatar
Default Re: how to get good color in tig welding (shortyz21)
Yeah that's what I was doing right now, welding it and making the second pass for coloring. Hopefully I can figure out a better way for time but for now that's the way i'm going to have to do it.
Old Jan 18, 2007 | 07:36 AM
legendboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir23 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that's what I was doing right now, welding it and making the second pass for coloring. Hopefully I can figure out a better way for time but for now that's the way i'm going to have to do it. </TD></TR></TABLE>
thats kinda dumb
Old Jan 18, 2007 | 07:43 AM
SequenceGarage's Avatar
Default Re: how to get good color in tig welding (legendboy)
so are customers that think colored welds are gangster
Old Jan 19, 2007 | 07:25 AM
crxsir23's Avatar
Default Re: how to get good color in tig welding (SequenceGarage)
my thoughts exatly but that's what some people wont
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SequenceGarage &raquo;</TD></TR><TR><TD CLASS="quote">so are customers that think colored welds are gangster</TD></TR></TABLE>
Old Jan 19, 2007 | 08:19 AM
SMSP's Avatar
What is the coloring from?
Old Jan 19, 2007 | 08:47 AM
danielm3's Avatar
Default Re: how to get good color in tig welding (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">What is the coloring from? </TD></TR></TABLE>
Exactly!
Old Jan 19, 2007 | 08:50 AM
david@didrace.com's Avatar
Contamination. Ideally if you're do stainless with 100% inert gas coverage the weld will just look like shiny stainless.
Here's what a stainless weld should look like (neither of these are mine).
Old Jan 19, 2007 | 11:12 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
if you wire brush your weld and u got no pitting or oxidation, its going to be just as strong as some colored weld..</TD></TR></TABLE>
And to add, if you wire brush afterwards, the weld is less likely not to rust in that haz area. I just learn this from talking to engloid, so my question is how come more people don't polish there stainless after its welded.
Old Jan 19, 2007 | 11:18 AM
Default Re: how to get good color in tig welding (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
And to add, if you wire brush afterwards, the weld is less likely not to rust in that haz area. I just learn this from talking to engloid, so my question is how come more people don't polish there stainless after its welded.</TD></TR></TABLE>
Because it doesn't look like a pretty rainbow.
Old Jan 19, 2007 | 11:20 AM
Default Re: how to get good color in tig welding (david@didrace.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">
Because it doesn't look like a pretty rainbow. </TD></TR></TABLE>
Or the reading rainbow ?
Old Jan 19, 2007 | 08:21 PM
crxsir23's Avatar
I guess i could clean the stainless better and see what happens but don't wont to leave zizwheel marks all over it. is their a chemical that i can use maybe
Old Jan 19, 2007 | 08:59 PM
SL0WEGG's Avatar
no, get some markers and color them lol
Old Jan 19, 2007 | 10:14 PM
TIGboy's Avatar
Default Re: how to get good color in tig welding (boostedej1)
SMSP, contamination is correct.
if you really really really want coloring, a Gas lense helps and very good cleaning of the stainless helps as well, im saying like stainless wire wheel and even mild grinding but very mild though. stainless to mild steel using 308 or 316L filler will really give you some coloring. the coloring is cool but doesnt at all promise a good weld. Remember that its even a good Idea to clean your filler rod before using it, And about what shortyZ said about how you go over the welds for coloring, that can give you a much weaker heat affected zone equaling in a weak weld unless your doing a root pass and then filling the rest in. This can also warp flanges very well!
Good luck! and keep welding.
Old Jan 19, 2007 | 11:35 PM
MidShipCivic's Avatar
SOOO EDUCATIONAL !
Old Jan 20, 2007 | 12:39 AM
TIGboy's Avatar
Default Re: (MidShipCivic)
heyyyy why not...
Old Jan 20, 2007 | 02:22 AM
mynameisjustin's Avatar
Loved
Community Favorite
the colors you want are silver or gold...do not ever go back over a weld
Old Jan 20, 2007 | 04:48 AM
crxsir23's Avatar
Default Re: (mynameisjustin)
i can get really good color when im on and off the petal exactly like i wont but iv got to figure out how to do this with consistancy and not on and off the petal this sux because im dame good with a MiG i now every body clams to be a grad A miger
Old Jan 20, 2007 | 05:51 AM
Loved
Community Favorite
use as little heat as possible and have good gas coverage. whipped this up real quick. havent migged in awhile so excuse the inconsitancy just a tad
Old Jan 20, 2007 | 09:15 AM
c jackson's Avatar
threes
if the color has been brushed away from a weld, im usually suspicious because that bit of color and haz tells a story of what the welder was doing when the piece was being worked on. a good welder knows how to make any color show at his demand whether it be dark purple or gold(with full penetration).
Old Jan 20, 2007 | 10:24 AM
SL0WEGG's Avatar
Default Re: (c jackson)
is it true full-race uses a special marker to get colors??
Old Jan 20, 2007 | 12:08 PM
arcboy's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir23 &raquo;</TD></TR><TR><TD CLASS="quote">iv seen some pepole in here tig and get this reddish coloring in their welds i can get good penetration and be Consistent with my welds but cant get that coloring the only way i can even come close is on ac and i have gas lenses also
</TD></TR></TABLE> If you are tig welding stainless than why are you using AC? Maybe a misprint.
Old Jan 20, 2007 | 12:10 PM
arcboy's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mynameisjustin &raquo;</TD></TR><TR><TD CLASS="quote">the colors you want are silver or gold...do not ever go back over a weld </TD></TR></TABLE>
Wrong!
Old Jan 20, 2007 | 12:12 PM
Default Re: (arcboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcboy &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong! </TD></TR></TABLE>
What color do you want then ?
