chipped sohc ecu work on dohc?
Old Jan 16, 2007 | 10:41 PM
dvsone's Avatar
Default chipped sohc ecu work on dohc?
I got a 94 accord with a 95 jdm h22a. Its has a p13 as of now unchipped. The kid originally had a jdm f22b boosted with low compression heads running on a P75 so the ecu says. But he had it rechipped and hondata programmed. Well he says it was a p28 and on top of the ecu it says p28 hondata ready. Question is if its really a p75 thats for a sohc non vtec correct? If its a p28 it can work with the h22a correct? How can I tell which it is? If I hook up the ecu and start the car will my vtec not work if its a p75? And if it is non vtec can it do damage if I hook it up and see if in fact it is a p28 with vtec? Or is there a way to see on the ecu that vtec is on by the connectors? Thanks a lot appreciate any opinions and knowledge. Obviously it won't be tuned right and I understand that in the event it does work but at least I know I have a chipped ecu I can use or maybe not use.
Old Jan 16, 2007 | 11:00 PM
dvsone's Avatar
Default Re: chipped sohc ecu work on dohc? (dvsone)
Also where it says hondata ready p28 written on the face it says p28 '93 MT can they convert a p75 to a p28 by chipping it and reprogramming in hondata?
Old Jan 17, 2007 | 09:26 AM
98vtec's Avatar
moderator emeritus
could be a p75 converted to vtec.
what does the code on the metal box of the ECU read?
if its a p28, the code will have p28 in it.
Old Jan 17, 2007 | 12:14 PM
dvsone's Avatar
Default Re: chipped sohc ecu work on dohc? (98vtec)
ya the ecu has the original p75 on it but I think it may have been converted but Im not sure maybe I'll just plug it in and expect the worst and hope for the best
chris42192
Texas -OK -LA (Sales)
Feb 25, 2010 06:24 PM
showbowt
Mar 19, 2008 03:06 PM
