93 accord oil light coming on... But only sometimes...
Old Jan 16, 2007 | 09:37 PM
Blaze45's Avatar
Brrraaaap!
Default 93 accord oil light coming on... But only sometimes...
I know that WHEN it does come on, the car is getting 5psi or less... The car had been leaking oil bad from the last time I changed the oil and so I got under the car and took a look, the filter was leaking so I got a new filter and its not leaking anymore. However, it has had a small leak which I pinpointed to be the cam seal. I replaced it this saturday. No problems. Car ran fine for 2 days. Last night when my dad was on the way to work, the oil light came on. He was at the top of a hill so he shut it off and coasted to work. This morning he started it up and drove it home without an issue. Tonight we were picking up another car and the light came on again. I popped the hood and took the oil cap off and looked in with a flashlight and could see oil flinging around like it was getting plenty of pressure. As soon as he let off the gas and the RPMs dropped, the oil light would come back on. He kept the RPMs above 1000 on the way to work tonight and the light didnt come on at all. After work tommorow Ill be picking up a gauge and checking the pressure. I didnt drop anything to my knowlege into the oil passages when I did the cam seal change and the oil level is perfect. Im leaning towards a possibly bad oil pump? Can the oil pressure senders go bad? The car has 182k on it. Do the F series motors have weaker pumps then some other Honda engines?
Any help would be great. Tia.
Blaze
Old Jan 17, 2007 | 02:00 AM
iam7head's Avatar
Default Re: 93 accord oil light coming on... But only sometimes... (Blaze45)
couple things:
1)what is the oil level?
2)check the oil pan, a dent could put the pump out of service
3)check the sender unit in the rear, see if there's any leak.
Old Jan 17, 2007 | 02:21 PM
JDMCB7Tuner's Avatar
Default Re: 93 accord oil light coming on... But only sometimes... (iam7head)
he said the oil level was fine but also yes oil sending units can go bad
Old Jan 17, 2007 | 02:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: 93 accord oil light coming on... But only sometimes... (JDMCB7Tuner)
About to check the sender & switch it out with a good known one.
Oil level is good.
Oil pan is NOT dented.
thx.
Old Jan 17, 2007 | 03:28 PM
Blamm!!'s Avatar
probably the sending unit
Old Jan 17, 2007 | 03:34 PM
Blaze45's Avatar
Brrraaaap!
Default Re: 93 accord oil light coming on... But only sometimes... (Blamm!!)
Replaced oil pressure sensor with a good one, cant get the oil light to turn back on....
Dakine69302
Jul 15, 2011 02:41 AM
hatmanafro
Jun 28, 2011 08:43 PM
Chevy/Honda Guy
Mar 16, 2010 12:40 PM
EG_Warped
Dec 26, 2007 06:43 PM
Blaze45
Jan 18, 2007 02:14 PM
