BC specIV vs. Scunk2 stage 2 for B20/GSR?
* B A N N E D *
BC specIV vs. Scunk2 stage 2 for B20/GSR? i'll be runnin 11:5 or 12:1 comp. and i'd like to keep the stock idle characteristics. will be tuning on dynojet. my goil is to make 220WHP hanging around 9000+RPMs. all positive input is welcome. thx.
Same vtec lobes. BC4's have larger primaries but are easily streetable. Mine idled at about 1100 with a bit of lumpiness. Even without tuning, they will both idle just fine. That's the advantage of variable valve timing. Now if you had a non-vtec head, your idle would dearly suffer with those vtec sized lobes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esohsee »</TD></TR><TR><TD CLASS="quote">if your looking for stock or close to stock idle get the skunk2 stage2's.</TD></TR></TABLE>
You ever run BC4's? They idle fine.
* B A N N E D *
ok the cam caricteristics i want. i want a close to stock primary with a hard cross-over to the vtec lobes. if i wont power i'll winde it past 5'800rpm. but for normal (not beating the **** out off my newly built motor) driving i'd like close to stock fuel economy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda »</TD></TR><TR><TD CLASS="quote">ok the cam caricteristics i want. i want a close to stock primary with a hard cross-over to the vtec lobes. if i wont power i'll winde it past 5'800rpm. but for normal (not beating the **** out off my newly built motor) driving i'd like close to stock fuel economy.</TD></TR></TABLE>
Having a hard crossover has no advantages. This is a ricer mentality.
* B A N N E D *
your kinda rite. but what i mean buy that is i'd rather have normal OE characteristics in my primary and all out performance in my secondary. maybe not the best idea if i wana get 220whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda »</TD></TR><TR><TD CLASS="quote">your kinda rite. but what i mean buy that is i'd rather have normal OE characteristics in my primary and all out performance in my secondary. maybe not the best idea if i wana get 220whp. </TD></TR></TABLE>
The smaller the primary, the more valvetrain wear that will occur when you do decide to cross into vtec.
Used2beAb16
Feb 9, 2006 09:20 AM
