Helicoil Instructions
My driver's side motor mount holes 2 out of 3 are stripped. I have experience using taps which was my first idea, however, I couldn't enlarge the holes of the motor mount even with a drill press because the metal is too strong. So I figured I try the helicoils.
Now, I have the helicoil inserts but do I need an install kit to use them? How do you insert them? Btw, the original bolts were m10 x 1.25, and I have m10 x 1.5 helicoils with new bolts matching that size.
To insert them, the kit will come with a bolt, you thread the coil onto the bolt. WIth the bolt you thread the helicoil into the bad threads.
I used a NAPA helicoil kit, came with everything you need. For about 25 bucks.
the kit should come with a tap...your gonna have to tape the whole before you insert the helicoil. the helicoil is ment to strengthen the whole being that the helicoil is SS
thrty8street
Aug 28, 2015 04:29 PM
webbs2jzgte
Jan 12, 2010 06:04 PM
