Help: Got a couple of problems with the car... (JDM h22 )
Old Jan 16, 2007 | 03:52 PM
i HEART my Honda's Avatar
Default Help: Got a couple of problems with the car... (JDM h22 )
Car is an 99 EK w/ a JDM h22a swap OBD1
1. Car is getting really bad gas mileage
2. Fumes from the exhuast is creeping into the cabbin and smells like crap
3. A lot of white smoke when starting the car first time in the morning
4. A friend says black smoke shoots out when im flooring it
5. When car is fully warmed up, the idle is around 1000, is that normal or am i trippin?
Some of the mods i have...
310 rc injectors
Intake
2.25 inch piping + muffler tip
EVERYTHING ELSE IS STOCK...
Old Jan 16, 2007 | 04:03 PM
Revi's Avatar
Default Re: Help: Got a couple of problems with the car... (i HEART my Honda)
Any cels? White smoke is no good, black crap out the back is normal while in WOT, its usually carbon buildup freeing up. Have you done a compression/leak down test? Sounds like you might be burning oil.
Old Jan 16, 2007 | 04:10 PM
PrecisionH23a's Avatar
What ecu are you running?
OBD1 injectors are 345cc and the obd1 p13 ecu is for 345cc injectors. Why did you downgrade to 310cc's?
Old Jan 16, 2007 | 04:15 PM
Default Re: Help: Got a couple of problems with the car... (PrecisionH23a)
i actually bought the car that way w/ the 310 injectors. Ill do a compression test ASAP. Anything else i should look for?
Old Jan 16, 2007 | 04:17 PM
Revi's Avatar
I would put the right injectors in for sure too.
Old Jan 16, 2007 | 05:09 PM
Default Re: Help: Got a couple of problems with the car... (Revi)
ill try to pick up some new injectors for sure. Anything else i should do about my other problems?
Old Jan 16, 2007 | 05:24 PM
rawNArsxS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">I would put the right injectors in for sure too.</TD></TR></TABLE>
so easy a caveman can do it
Old Jan 16, 2007 | 05:26 PM
xthekidx's Avatar
complete tune up
check cel codes
sounds like you have a compression leak or something to that effect if youre getting both kinds of smoke out the pipe. lol damn.
it just needs some tlc.
if it was me id at least go down as far as the piston rings.
thats just my opinion.
but a tune would help it a lot.
rotor, plugs, plug wires, fuel oil and air filters, that ****.
Old Jan 16, 2007 | 05:40 PM
Revi's Avatar
Default Re: Help: Got a couple of problems with the car... (rawNAprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNAprelude &raquo;</TD></TR><TR><TD CLASS="quote">
so easy a caveman can do it </TD></TR></TABLE>
Damn this shiet is getting old, everyone is saying that to me now!
Old Jan 16, 2007 | 05:48 PM
rawNArsxS's Avatar
lol im sorry i couldnt resist. i love those commercials
Old Jan 16, 2007 | 09:11 PM
vinuneuro's Avatar
Cat / O2 sensor
Old Jan 16, 2007 | 10:40 PM
Default Re: Help: Got a couple of problems with the car... (vinuneuro)
cool thanks guys for all the input!
Old Jan 17, 2007 | 04:06 AM
kulrevon's Avatar
what ecu are you running?
fabe85
Jun 19, 2007 09:14 PM
Pikachu
Mar 31, 2005 04:07 PM
whagkangmakulet
Dec 24, 2002 07:21 AM
Pro-Lude
Nov 7, 2001 06:55 PM
