Have u guys ever had this happen (02 sens conec.)
Old Jan 16, 2007 | 03:29 PM
loup05's Avatar
Default Have u guys ever had this happen (02 sens conec.)
i have been having a misfire and a hesitation problem with my 95lx. i thought it was the egr ports so i opened them up adn sure enough they were clogged up. i cleaned them and i stil had the problem so i decided 2 get a new 02 sensor (free btw). i go to disconnect the 02 sensor i noticed that one of the four pins on the wiring harness part of the conector is missing. looks like it burn out or something.
Does anyone know how i can fix this? i callled the dealership but they said i would have to buy a new wiring harness. im wondering if i can just go 2 a junkyard and cut off the conector and put it onto my car. i dont want to do any crapy work. one of my friends said that the wires going to the conector just pop off. i noticed they have a metal part going to the conector. has anyone done this?
Old Jan 16, 2007 | 03:40 PM
TheMuffinMan's Avatar
He knows where you live!
I would say your best bet is junk yard and SOLDER it together that's the best repair, and then heat shrink or electrical tape
edit* I did this for the repair of my radio harness, power windows, and power locks so it's fine
Old Jan 16, 2007 | 03:48 PM
hondadude's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">I would say your best bet is junk yard and SOLDER it together that's the best repair, and then heat shrink </TD></TR></TABLE>
At the junkyard just chop off the side of the connector you need
Old Jan 16, 2007 | 06:07 PM
19dabeast85's Avatar
Default Re: (hondadude)
Make sure that the wire length is exactly the same as your stock harness and that you have a very good solder connection because you want the same resistance through the harness as stock so that your ecm doesn't think something is screwed with the A/F ratio.
Old Jan 17, 2007 | 02:50 PM
BlUAc's Avatar
Default Re: Have u guys ever had this happen (loup05)
and make sure it is not off of an ex model the plugs are backwards
Old Jan 17, 2007 | 03:15 PM
loup05's Avatar
Default Re: Have u guys ever had this happen (BlUAc)
Thats what i am worried about. if i solder the wiring wont i have a diff resistance? like i said earlier my friend said that u can just pull the 4 wires out without damaging anything. he said that they have metal tips. can anyone confim this?
Dom93
Jul 26, 2012 01:36 PM
reed6
Apr 11, 2010 10:56 PM
92civicx
Mar 18, 2008 10:39 AM
naveedk
Honda Civic (2001 - 2005)
Mar 15, 2008 02:35 PM
Pooby88
Feb 26, 2006 09:51 PM
