JDM type R vs. JDM GSR
Old May 15, 2002 | 01:28 PM
DC2_Jspec's Avatar
Default JDM type R vs. JDM GSR
How can I tell the difference between a jdm type R and a jdm GSR engine WITHOUT TAKING OFF THE HEAD or going into the engine at all--I am speaking purely from a visible aspect ??? (besides the obvious: valve cover, intake manifold). thanx in advance.
Old May 15, 2002 | 01:30 PM
sgT's Avatar
sgT
Default Re: JDM type R vs. JDM GSR (DC2_Jspec)
you cant.
Old May 15, 2002 | 01:31 PM
Turbo R's Avatar
hahahaaha......nothing more
Old May 15, 2002 | 10:04 PM
mugenracer's Avatar
All JDM Si/SiRs (GSRs) engine numbers start B18C 100XXXX and it should be stamped on the engine on LHS below valve cover, plus the Si/GSR distributor has two grey plugs at the rear whereas the JDM ITR has only one plug, i know this for sure as my friend with a JDM ITR bust his dizzy and thought that an Si one would do but found it wont.
Old May 15, 2002 | 10:08 PM
sgT's Avatar
sgT
Default Re: JDM type R vs. JDM GSR (mugenracer)
in 1996 they went from 2 plugs to 1 plug.
Old Nov 23, 2002 | 06:22 PM
JDMCRX's Avatar
Default Re: JDM type R vs. JDM GSR (sgT)
look at the stamp on the heads ITR is a P73 i think
Old Nov 23, 2002 | 06:31 PM
IN VTEC's Avatar
Default Re: JDM type R vs. JDM GSR (JDMCRX)
Ummmm...how about PR3?
P72 motors use a dual-stage intake manifold.
Old Nov 23, 2002 | 06:47 PM
MiraiZ's Avatar
Default Re: JDM type R vs. JDM GSR (IN VTEC)
exhaust manifold
intake manifold
(going purely by visual)
Old Nov 23, 2002 | 06:48 PM
92TypeR's Avatar
FSAE
JDM ITR 98 spec = PR3-4 I'm not sure about 96-97 but I know its PR3.
GSR = P72
[Modified by 92TypeR, 7:48 PM 11/23/2002]
Old Nov 23, 2002 | 07:09 PM
UNVMYR's Avatar
Default Re: JDM type R vs. JDM GSR (92TypeR)
mines, a 97 and it has pr3-2,whos to say what the block came from.any one can slap a b16a head on a jdm gsr and call it an R or any jdm c block.
Old Nov 23, 2002 | 07:38 PM
fowler!'s Avatar
Default Re: JDM type R vs. JDM GSR (UNVMYR)
ITR head has the radiator hose below the distributor.
GSR head has the radiator hose below the vtec solenoid.
GSR head is marked by P72
ITR head is marked by PR3
Blocks are identical minus the pistons and a few other internals.
Old Nov 23, 2002 | 10:28 PM
Paste's Avatar
Loved
Default Re: JDM type R vs. JDM GSR (NA ITR)
wtf is the point of that?
[Modified by paste, 12:29 AM 11/24/2002]
Old Nov 24, 2002 | 11:55 AM
b18c-rDC2's Avatar
Default Re: JDM type R vs. JDM GSR (paste)
If you dont know just go stare at each one for a while at a local shop or in a friends car, after you look at them so many times you'll know the differences... Fowler stated most of them...it's easy to tell dont stress it, but if you can, check out the pistons and make sure its says pr3 on the head! Or better yet bring someone with you who KNOWS!
Brian Pumper
Nov 25, 2008 07:01 PM
crxd88
May 22, 2008 08:47 AM
jdm0ua
Jun 9, 2006 12:53 AM
spoon23_JDizM AkA SpOoN20
Oct 29, 2005 07:15 PM
Yellow Dragon
Feb 25, 2002 09:01 AM
