**Searcehd** Air/fuel ratio guage install.
Old Jan 15, 2007 | 07:12 PM
Brycen's Avatar
Default **Searcehd** Air/fuel ratio guage install.
Ok installed air/fuel ratio guage last night instead of hooking the purple wire which is the o2sensor wire to the whie wire on the ECU i ran it to the white wire on the o2 sensor.Once i did that the littel green bar went away on the guage and nothing happends,i unplug the sensor wire and it comes abck.I cannot figure out why it is not showing up on the guage.I have a 95 civi SI with the Z6 motor.Any help is appriciated.I have done a search onit and came up with nothing.
Old Jan 15, 2007 | 07:19 PM
Syndacate's Avatar
Default Re: **Searcehd** Air/fuel ratio guage install. (Brycen)
What type of <u>wideband</u> O2 sensor are you using?
Old Jan 15, 2007 | 07:21 PM
Brycen's Avatar
Default Re: **Searcehd** Air/fuel ratio guage install. (Syndacate)
its just the factory o2 sensor with an autometer phanton gauge.Its the purple wire out of the guage into the white wire on the o2 sensor like it says when i search ttt
Modified by Brycen at 8:52 PM 1/15/2007
Old Jan 15, 2007 | 07:52 PM
Brycen's Avatar
never mind guys i did a more in depth search and found the autometer guage will not work with the narrowband z6 : /
Old Jan 15, 2007 | 08:02 PM
EX-T's Avatar
How much did you pay for the gauge?
Old Jan 15, 2007 | 10:00 PM
Brycen's Avatar
Default Re: **Searcehd** Air/fuel ratio guage install. (EX-T)
it is a phantom II guage i paid 75 dollars for it at a speed shot.
Old Jan 16, 2007 | 01:38 PM
Brycen's Avatar
just to let everyone know that i got the guage to workwith the z6 motor it goes on the blue wire on the O2 sensor no need for a wideband gauge.
BUMP
krysted9354
Jan 24, 2009 06:23 PM
Crab Man
May 18, 2007 06:43 PM
71 mgb
Jul 20, 2003 09:35 AM
SlammedHatch90
Dec 22, 2002 05:14 PM
CiViCxR
13
Feb 13, 2002 12:46 PM
