just picked up s2k wheels for my 5th gen, doesnt fit!?
Old Jan 15, 2007 | 01:03 PM
porter's Avatar
I'm a Jackass
Default just picked up s2k wheels for my 5th gen, doesnt fit!?
i was searching and saw alot of people running fronts on the front and rears on rear. maybe its the tire size the wheels came with?
the fronts came with 225's and rear with 245's im gunna put the 225's in the rear and get some 205 or 215's for the front
will that make it fit? right now its hitting the upper control arm
Old Jan 15, 2007 | 01:11 PM
GO-FIGHT-KILL's Avatar
You're putting the rears on the front? That's why. The wheel itself may be too wide. Sell the rear wheels, and buy 2 more fronts. 215 all the way around would be great.
Old Jan 15, 2007 | 01:13 PM
1GPlusSH's Avatar
Default Re: just picked up s2k wheels for my 5th gen, doesnt fit!? (krogers)
Just buy another front set. have 225 all the way around
Old Jan 15, 2007 | 01:20 PM
porter's Avatar
I'm a Jackass
did u guys not rear what i said? i said i was putting the fronts on the front and rears on the rears.
i see alot of 5th gens running a complete set of s2k's fronts and rears
Old Jan 15, 2007 | 01:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krogers &raquo;</TD></TR><TR><TD CLASS="quote">did u guys not rear what i said? i said i was putting the fronts on the front and rears on the rears.</TD></TR></TABLE>
^ Why don't you lose the attitude? You're not exactly the most clear poster ever, maybe we got confused by your jumbled words? Who knows. Give us a break, we're trying to help YOU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krogers &raquo;</TD></TR><TR><TD CLASS="quote">i see alot of 5th gens running a complete set of s2k's fronts and rears</TD></TR></TABLE>
Fine, I guess you know everthing, since you've seen it done before. Good luck figuring it out.
Guess you really need those wider wheels in the rear... Since... Well, you know. Preludes are RWD.
Old Jan 15, 2007 | 01:29 PM
1GPlusSH's Avatar
will that make it fit? right now its hitting the upper control arm</TD></TR></TABLE>
to your two questions...yes, yes.
So...you're going to take the 245s off the rim and put 205s or 215s on? And why are you putting the more tire in the back? What width are the s2k wheels, 7.5? I have no idea how that would be with 205s....
Old Jan 15, 2007 | 01:32 PM
1GPlusSH's Avatar
Default Re: just picked up s2k wheels for my 5th gen, doesnt fit!? (1GPlusSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GPlusSH &raquo;</TD></TR><TR><TD CLASS="quote">What width are the s2k wheels, 7.5? I have no idea how that would be with 205s....</TD></TR></TABLE>
I love quoting myself. I just checked, and there are some autocross guys that put 205s on 7.5 width rims. I'm sure if it's going to stand up to that, it would work on the street.
Old Jan 15, 2007 | 02:02 PM
porter's Avatar
I'm a Jackass
im gunna put the 225's in the rear and see how that works and put either 205's or 215's in the front
Old Jan 15, 2007 | 02:24 PM
1GPlusSH's Avatar
You already covered that. If you're going to get huffy when people don't answer your questions exactly, you should answer people's questions exactly.
Old Jan 15, 2007 | 03:28 PM
Hawkze_2.3's Avatar
So why can't you run yours smarty pants?
Where does it hit on the UCA?
Old Jan 15, 2007 | 04:24 PM
porter's Avatar
I'm a Jackass
not trying to be a smarty pants just thought by now everyone on h-t could read/comprehend? i mean i didnt formally type it out or anything but i thought i got my point/question across. lets just get back to the topic at hand
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
the top of the tire rubs it a lil. it hits it a lil under the castle nut
Old Jan 15, 2007 | 04:31 PM
madcatz's Avatar
no you see...your engrish put us in this downward spiral and I for one wont let it go...these other guys....yeah not them either
Are you using any wheel spacers....pics would be so ever helpful right now too
age 105....you cant be more than 17 right? Mommy and Daddy bought you the wheels because you want to be ever so popular in the high school parking lot because Suzy slutty pants shot you down
Old Jan 15, 2007 | 04:32 PM
ethereal2pt2's Avatar
if you're going to get all pms on us than forget about getting help. honestly, some manners would go a long way, even if it's the interweb.
i normally see ppl running the s2k rims fine w/o adjustments when they're running stock s2k size. with your attitude i doubt you'll get very far with this thread. this subject has been covered many times, try searching for it. before you even try saying it's not there, it is, just search.
Old Jan 15, 2007 | 06:04 PM
Guess I'm not the only one who has a problem with the way you compose yourself on here... Maybe that means something?
Just change your attitude when you COME TO US asking a question. We're not looking at it in front of us, you may have to explain it a few different times, a few different ways to help us understand.
Guess that makes us retarded.
Old Jan 15, 2007 | 06:13 PM
madcatz's Avatar
Im a weetard
Old Jan 15, 2007 | 06:15 PM
98vtec's Avatar
moderator emeritus
Default Re: (madcatz)
can we just answer his questions please?
Old Jan 15, 2007 | 06:16 PM
Wsteun's Avatar
Um, if I read this thread correctly, the OP stated he was going to be running a set of S2K wheels. Fronts in the front, and rears in the rear. You misunderstood and then you guys get all pissy when he asks if you had read what he said. See the problem with communication over the internet is the lack of tone and meaning.
To the OP, I know a full set of S2K wheels can be run, however I don't know if it requires spacers in the rear or a different tire size. I'm sure someone on here will be able to answer your question.
Old Jan 15, 2007 | 07:10 PM
Default Re: (Wsteun)
well if he read my post i already answered his question. someone here is running stock s2k tire sizes on his lude. fronts in the front. rears on the rear. that would be 205/225 if im not mistaken. sooooo you put two nd two together.. and yes.. they'll fit without modifying them. at least that's what that guy said. i can't remember his name. not convinced? search ap1 s2k rims or something to that effect and you'll find his thread eventually. guess that means we're done here boys..
honda_andy's Avatar
i dont see anything wrong with this explaination, nor did i see any attitude in his other posts in this thread.
to get back on topic, i believe you had the problem because the s2k came stock with 205's in the front and 225's in the rear and that would fit fine on the prelude, but it seems like the previous owner of the rims got wider tires front and rear. so ya, if you put the 225's on the back and 205's in the front, it would work.
Old Jan 15, 2007 | 07:14 PM
Default Re: just picked up s2k wheels for my 5th gen, doesnt fit!? (honda_andy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_andy &raquo;</TD></TR><TR><TD CLASS="quote">
to get back on topic, i believe you had the problem because the s2k came stock with 205's in the front and 225's in the rear and that would fit fine on the prelude, but it seems like the previous owner of the rims got wider tires front and rear. so ya, if you put the 225's on the back and 205's in the front, it would work. </TD></TR></TABLE>
thanks i believe i already said that
reading owns you
Old Jan 15, 2007 | 07:21 PM
honda_andy's Avatar
Default Re: just picked up s2k wheels for my 5th gen, doesnt fit!? (_BB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BB6 &raquo;</TD></TR><TR><TD CLASS="quote">
reading owns you</TD></TR></TABLE>
actually, i believe reading owns you, check the time of our posts. i cant type a reply and read your responce at the same time. thanks genius
Old Jan 15, 2007 | 07:27 PM
i was referring to my first post brainiac. the comment you were referring to was simply me repeating what i had already stated above since ppl didn't notice. i even had it bolded for ppl like you. reading owns you again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BB6 &raquo;</TD></TR><TR><TD CLASS="quote">if you're going to get all pms on us than forget about getting help. honestly, some manners would go a long way, even if it's the interweb.
i normally see ppl running the s2k rims fine w/o adjustments when they're running stock s2k size. with your attitude i doubt you'll get very far with this thread. this subject has been covered many times, try searching for it. before you even try saying it's not there, it is, just search. </TD></TR></TABLE>
edit: btw, yes you can read and type a response at the same time. ever heard of copying? sure you have..
Old Jan 15, 2007 | 07:32 PM
honda_andy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BB6 &raquo;</TD></TR><TR><TD CLASS="quote">i was referring to my first post brainiac. the comment you were referring to was simply me repeating what i had already stated above since ppl didn't notice. i even had it bolded for ppl like you. reading owns you again.
you simply stated stock s2k size, i stated the actually size of the tires, i also wanted to back the guy up since ****** like you were saying he was speaking with attitude when in reality, it wasnt rude at all. enough of this, i have better things to do than to keep replying to retards on h-t.
Old Jan 15, 2007 | 07:40 PM
you're right. this is pointless to argue about. is it that hard to search ap1 s2k tire size on google? i doubt it'd take you no more than 1 min. and what do you know. it says it right there in the first result. furthermore, if he simply searched the forum he'd have found the answer he was looking for. because i found it by searching. whether he was giving an attitude or not is beyond the point here and is arbitrary. it's surprising how ppl can't even admit their wrong. well since the op hasn't comment it seems like we're done here..
Modified by _BB6 at 9:42 PM 1/15/2007
Old Jan 16, 2007 | 02:54 PM
UKMotegi's Avatar
AFAIK you need to run 4 fronts all round to fit S2k wheels onto a Prelude...
Afew people have done that and have been ok. I notice afew others have stated that aswell, i think that would be your best option.
m R g S r
Honda S2000
10
May 29, 2007 02:32 PM
budget
Jan 2, 2007 01:27 PM
kihun_cha
Dec 15, 2006 12:28 PM
DruWO
Jan 25, 2006 05:45 PM
577HondaPrelude
Oct 6, 2005 05:42 PM
