DA integra knuckles "hubs" on 89 EF???? help!!!!
Old Jan 15, 2007 | 11:21 AM
wunPOINTeight's Avatar
Default DA integra knuckles "hubs" on 89 EF???? help!!!!
i was wondering if it possiable to fit 90-91 integra "spindles" on my 89 si civic hatch?
Old Jan 15, 2007 | 11:24 AM
dephtone's Avatar
Yes they will fit, are you going to use the spindles so you have bigger brakes? My friend has his whole front suspension from a 92 teg for his b18 swap on his 89 sedan.
Old Jan 15, 2007 | 11:39 AM
cool, thanks bro , also would i be able to use the rear disc brakes with out having to modify stuff?? or is it basically bolt on ???
Old Jan 15, 2007 | 01:57 PM
dephtone's Avatar
Bolt on, just make sure you use your LCA's or both DA Lower Control Arms. When we swapped all the suspension over, we bought Russell Stainless Steel Brainded brake lines from Summit, I think it was like 40 bucks for all 4 corners, but prices might have changed. If you plan on doing that, make sure you use the booster from the DA or you will have the DA brakes but still stop like you had your old brakes.
Old Jan 15, 2007 | 01:59 PM
BlackLudeSi's Avatar
Default Re: (dephtone)
Make sure you use the correct prop valve too.
Old Jan 15, 2007 | 02:26 PM
Tyson's Avatar
Default Re: (wunPOINTeight)
you are asking about a DA "big brake" upgrade. its been done lots of times.
https://honda-tech.com/zero...age=1
EF88Ty
Oct 16, 2018 10:33 AM
jdmdingdong
10
Jul 20, 2012 11:40 AM
anthrax718
11
Jul 5, 2009 08:07 PM
JokerTypeR
16
Nov 19, 2006 11:07 AM
mekanism
Jan 19, 2005 05:43 PM
